ex7000hd updates
  • slyjoe
    • 5
    ex7000hd updates
    wassup with the new box anyone with info pleass let me know
  • chic.
    • 1599
    Hi welcome to the forum what is the problem with it let us know and then we will help ps mine is ok
    if i helped hit the thanks btn
    • slyjoe
      • 5
      i dont know how to setup the box
      • chic.
        • 1599
        ok go to downloads get the latest firmware 12/3/09 click it to unpack it then rename the flash flash.tbn when you have done this put it onto your memory pen then into the back of the box switch off/on at the back of the box the box will reboot find the flash and install it when this is done press menu > deep installation > scroll to your symbole rate then press the blue btn all done good luck
        • Nemo69
          • 7
          manuall update of the codes on 7000hd
          I'm new in this forum. I just bought a hd7000 but i don't know how i can manually put the codes. Is anybody can help please?
          I prefer to put codes rather than updating the S/W as it would affect the warranty.
          Thanks a lot
          • mtv1
            The Stig PT
            • 4413
            you should update it m8 the eurovox are a good make and rarely go wrong but i think if you press yellow a window appears it does with older models
            • Nemo69
              • 7
              Hi Thanks for reply
              I have tried yellow button it dosen't work the same as eurovox max . Is there any other way?
              • chic.
                • 1599
                as mtv1 has said its better to flash your box( by the way its menu then the blue btn)
                • Nemo69
                  • 7
                  I did try menu and blue btn as well it didn't work
                  • Nemo69
                    • 7
                    I have S/W Ver: 01.01-00
                    and it was updated on Jan 14, 2009
                    • chic.
                      • 1599
                      you need to flash the box or you will get only fta channels and no hidden menus it will stay a fta box till its flashed
                      • Nemo69
                        • 7
                        Thabk you very much guys I updated and it work perfectly. I have just noticed that the strength and quality level is above 90% hwereas with my eurovox Max it was about 80-85%. I wonder if it is normal.
                        • chic.
                          • 1599
                          mine is the same if the pic is ok then leave it
                          • Nemo69
                            • 7
                            yes the pic is good. Thanks
                            • andcel
                              • 6
                              BOX NOW WORKING A BIG THANKS FOR YOUR HELP NOW ALL I HAVE TO DO IS TRY AND SORT OUT THE CHANNELS
