Eurovox Red - No signal
  • munni
    • 16
    I am just after some updates if any. i have had no or bad signal for most of my channels now for quite a few months. the only channels i can watch without problem is the sports channels.
    Rumour had it VM are doing some tests.
    Is there anything that i can do to get all my channels back again?
  • chic.
    • 1599
    you may have a low signal remove any splitters
    if i helped hit the thanks btn
    • munni
      • 16
      i have tried thiis but it doest make any diference. my box is fine as well as it works elsewhere.
      • chic.
        • 1599
        if it is working elswhere then it must be your feed
        • munni
          • 16
          what about the feed? my internets working and if i use my virgin box that works too.
          • smoggy
            • Apr 2009
            • 12774
            internet and vm boxes can work on a lower signal than eurovoxes
            check what signal strength you are getting on some of the bad channels (press the remotes info button twice)
            have you tried a factory default reset and powerscan
            • munni
              • 16
              yeh ive done a factory reset and rescanned all the channels. its the last few chanels that work (which happen to be the sports channels).
              i will check the signal strength when i get home on the ones that dont work.
              • munni
                • 16
                the channels that i get no signal messages on fluctuate between 78% and 82%.
                • smoggy
                  • Apr 2009
                  • 12774
                  that signal strength appears ok but if the box is working ok elsewhere then it can only really be a signal issue (check signal level at the place its ok to give you an idea of what strength is needed), I would also try remaking all your connections
                  not sure if the red firmware has the signal booster option but if it has try turning it on
