hard drive for ex6000sd
  • thedon2211
    • 45
    what are the limitations of hard drive for ex6000sd.
    ie. whats the max size, do 5400 and 7200rpm drives work ok,
    does it have to be ide, or do sata 1 and sata 2 drives work aswell.
    never had eurovox before used to dbox2.
    any help
  • gadgetfiend
    • Aug 2008
    • 355
    You do know the hdd connects via USB right ? i cant imagine it therefore having any limitations other than for larger drives (excess of 500gb)I would probably recommend that they have their own psu and are not usb powered. I might just be havering though thats just my own thoughts.
    • thedon2211
      • 45
      yes i do know its usb.
      prob get around 250gb, its the other questions i really need to know.
      thanks mate
      • gadgetfiend
        • Aug 2008
        • 355
        im using an IDE 120gb drive but see no reason why it wont support sata dont have 1 to try though.
        • smoggy
          • Apr 2009
          • 12774
          I don't know personally but I have seen a flashing guide that states the max drive size is 320gb
          • satsmo
            • 6397
            Was it this one smoggy? It was passed onto me, but looks like a supplier add on doc, given it says box "comes flashed".
            Tests were conducted up to 320GB on bus powered drives, but I have also tried a WD 500GB powered drive and it works perfectly well so far.
            • gadgetfiend
              • Aug 2008
              • 355
              My son wants 1 off these for xmas and i was going to get him a 1tb powered drive as well as he is a mad movie downloader so if anyone has a 1tb one and can try it for me i would be obliged.
              • smoggy
                • Apr 2009
                • 12774
                yes thats the one satsmo
                I did have some doubts thats why I put I didn't know personally
                thanks for the extra info, much appreciated
                • satsmo
                  • 6397
                  Sorry I had to borrow one so could not answer earlier.
                  I tried a powered WD My Book 1 TB. I tested a 1 hour TS from the box and both recording and playback were fine. The drive was empty and I had formatted it to FAT32 beforehand.
                  I transferred across approximately 250GB of movies, (payback for borrowing it ), to the drive so it wasn't full by any means. But good enough for test purposes I hope.
                  I converted a couple of avi movies to MPEG-2 and again playback was perfect on the EX6000.
                  • gadgetfiend
                    • Aug 2008
                    • 355
                    thanks for that m8 i appreciate it.
                    • satsmo
                      • 6397
                      No bother although getting through 1TB of movies will be quite a feat for your young lad
                      • gadgetfiend
                        • Aug 2008
                        • 355
                        once converted to mpeg2 he should get about 250 movies on it trust me he'll have that many d/led for the end of january....
                        • satsmo
                          • 6397
                          I know I have a son doing exactly the same thing. I blame the parents for introducing him to certain servers
                          • gadgetfiend
                            • Aug 2008
                            • 355
                            monkey see monkey do m8....
