yes i am in a telepest area, and the new firmware is hopeless, it does look like its for pure ntl only, i have reverted bck to the march version, epg still needs improving though
epg and new 7000 firmware
Hi m8 welcome to the forum
flash the box with this http://www.digital-kaos.co.uk/forums...d=988&act=downif i helped hit the thanks btnComment
read this i have posted this so many times that i have now saved it on my pc
when you have downloaded the firmware click to open it, and rename the flash , flash.tbn, put this onto your memory pen then into the back of the box , switch the box off/on with the switch at the back , the box will then reboot ,on the led on the front of the box it should say now booting , open flash , extracting flash then count up from 0 to 100 then reboot , you may have to do a deep scan using the symbol rate for your area 6887 or 6952.if i helped hit the thanks btnComment
I'm in belfast and I had limited success with the new firmware and had to revert.
I used to have programme names for all channels but no info.
With new firmware I get programme names AND info for some channels but the rest I get nothing (not even programme names)Comment
Hi, any chance of some help. i seem to have managed to get into a real mess with my new eurovox hd 7000. So i plugged it in last night and did the ez install. I had all the channels on the list but all but the standard terrestrial channels were saying scrambled so i assumed i needed to update the firmware so i downloaded the 03.12.09 firmware, went through the process of putting it on my usb stick then turning the box off and on and the box said it was writing the firmware. However, since the box rebooted all it is saying is 'Invalid Data' on the screen and i am unable to do anything, literally apart from turning the box off and on at the back. The only thing i feel like i may have done is not unzipped the download file properly. Any help!! Very worried i've broken my box!.
Thanks anyone.
KristovComment
