EX1100 Dec 17th Beta Firmware
USED FOR A FEW DAYS NOW
HAD FIRMWARE FOR A FEW DAYS & EPG IS STILL WORKING FINE.
ONLY SLIGHT PROBLEM IS THE FUZZY SOUND EVERY NOW & THEN AS THOUGH CHANNEL IS LOSING SIGNAL THEN REGAINING SIGNAL.
BUT CHEERS FOR THIS FIRMWARE.CHEERS,NEDSTERComment
Firmware problem, EX1100 Dec 17th Beta Firmware
been waiting two months for this Firmware epg works great
only problem is when you turn off your box you can still
see the channel running with out any sound,
so the box has not fully turned off ( tunner is still on )
some of the last Firmware gave me the same problem
but the epg works great manythanks
but hope someone can fix the turning off problem
I have had a problem with epg, just got it for christmas. Will this help? The one my mam and dad have is slightly older but works fine. CheersComment
did u factory reset after loading new firmware and rescan ?been waiting two months for this Firmware epg works great
alexComment
yes,
i tryend everything but still get the same problem
when you turn off the box the led gos red,
but can still see the picture with no sound
am sure every body is having the same problem
cos as soon as i loadup the old Firmware
it fixs the problem but epg is slow
please check yoursComment
NEW ETA WORKS OK JUST BREAKUP OF PICTURE NOW & THEN
MUST BE YOU BOX MATE.yes,
please check yours
I HAVE THE NEW DEC BETA FIRMWARE INSTALLED & EVERYTHING WORKS & SWITCHES OFF WHEN YOU PUT IN STANDBY.
THE ONLY BUG I HAVE IS THE BREAKUP OF PICTURE EVERY NOW & THEN THAT MAKES SOUND GO FUZZY BUT STILL THE EPG IS PERFECT.Last edited by NEDSTER1972; 27 December, 2009, 09:12.CHEERS,NEDSTERComment
Installed the new firmware, but have the issue of sluggish channel listing that others are experiencing. hopefully the next update will fix this last issue.Comment
