Eurovox 5000
  • playstation
    • Sep 2009
    • 5
    Eurovox 5000
    Have done deep scan and got channels but cant locate sports in the fav section also how do i get to show all channels in alphabetical order
  • chic.
    • 1599
    not suer what you mean , have you got the channels but cant put them in favs ? or dont you get them after you deep scan ? if the latter then do a factory reset delete all channels then deep scan (without any splitters ) on the symbole rate for your area , you will have to redo your favs so have a look in downloads for a cdf for your area.
    if i helped hit the thanks btn
    • johnboy1974
      • 3418
      press menu/channel manager/ enter code 0000 then press red button twice to sort into alphabetical order.
      • lee1974
        • Apr 2010
        • 15
        hi, can someone advise me how to flash eurovox5000 pvr.. bought cables and waiting . my channels are scrambled. only get free to air channels.. cheers
        • badapple
          • 2041
          Hi m8 welcome to DK.
          This is the firmware you need to install >Digital Kaos - Downloads - UFL_EX5000PVR_24-02-09_DarX
          And this is how to do it
          > http://www.digital-kaos.co.uk/forums...-eurovox-9790/
          > http://www.digital-kaos.co.uk/forums...settings-9789/
          SLOWLY, OUR FREEDOM IS BEING ERASED.
          SOON, WE WILL JUST BE A NUMBER.
          IF WE DON'T FOLLOW, WE WILL BE ERASED.
          • lee1974
            • Apr 2010
            • 15
            thanks for reply,, im going to sound stupid now, but ufl? how do i download it..
            • lee1974
              • Apr 2010
              • 15
              hi, just downloaded ufl from your link, cheers.. it tells me waiting for responce from receiver? can you help please
              • badapple
                • 2041
                Have the box power switched OFF, then run the software, hit download and switch power ON when message comes.
                • lee1974
                  • Apr 2010
                  • 15
                  still no joy, even when power off, click download , just says waiting for responce ?
                  • badapple
                    • 2041
                    What com port are you using? It should be 1,2,or 3.
                    Go into device manager of PC and check. try 1,2,or 3 one will work.
                    • lee1974
                      • Apr 2010
                      • 15
                      com 3 , the only one that lets me, but keeps leaving me on that window. waiting.. sorry to be a pain?
                      • badapple
                        • 2041
                        What cable are you using, null modem on its own or with a USB adaptor?
                        Have you tried changing com port. Try on com port 1.
                        • lee1974
                          • Apr 2010
                          • 15
                          using usb to my lap top, connected that to female null cable, which connects to box. you know com 1,2,3 ..which end is that, mt usb port? or box? just tried different port on usb
                          • lee1974
                            • Apr 2010
                            • 15
                            just checking.. plugged in both box and lap top, box is off ,click download ,window opens com 3 start, click start, another window boot mode, select com 1,2 or 3 . click ok, window opens firmware download version 2.00 waiting for reponse from receiver? is this right what im doing?
                            • badapple
                              • 2041
                              OK are you power ON box when message appears?
