lost channels on Eurovox Teesside
  • kdbrown
    thanks for the info
    • cheesesofnazareth
      I too live in Teesside (Linthorpe) and am also missing Sky Sports but i am also missing bbc 1/2/3/4 e4 film 4 sky premier and several others. So to get this straight, if i either do a manual scan on those channles, or a factory reset, this should get them back? Am i right in assuming if i do a factory reset, i will need to re-upload the firmware?
      • smoggy
        • Apr 2009
        • 12774
        #18
        Hi and welcome to DK
        you will not need to re-load the firmware
        the factory default reset will erase all the channels good and bad then the powerscan should get all working channels back but they will be all mixed up and need to be sorted
        • christinebula1
          • Feb 2010
          • 9
          #19
          New to the site also i have Eurovox too and i lost channel 5 and some other digital ones ,they were off for about 2 days then just came back on,very strange as i lost other channels a few weeks ago and had to get someone in to do all the resetting etc as i didnt have a clue
          • ryanjohns
            • Feb 2010
            hello been to factory reset and then done the powerscan but still no luck where is it that you put the frequency figures in on euro vox max
            • pwilkinson
              • 8
              #21
              Sorry for jumping in on this but I am in Stockton On Tees setting up a new box and most of my channels have $ sign in front of them and therefore scrambles. I have reformatted my usb to fat32 I have tried 2 different firmware and I am doing a deep scan on 6887. If anyone has any ideas where I am going wrong it would be greatly appreciated!
              • Fergal
                • Aug 2008
                • 1007
                #22
                You can manually add frequencys in the installation menu
                Press menu,press ok on language then type 1968 twice press default key and turn emu on and exit out and change to a blank channel and wait 5 mins
                • pwilkinson
                  • 8
                  #23
                  I went onto language settings and it does not give the option to type in numbers but I tried anyway and did not get anywhere.
                  Really sorry but you might have to baby walk me through it, this sort of thing is not my forte as you may have already guessed!!
                  thank you in advance
                  • Fergal
                    • Aug 2008
                    • 1007
                    #24
                    Press ok on language so you see english then type 1968 twice using the numbers on the remote it should show you a hidden menu
                    what box is it and what firmware did you flash on
                    • pwilkinson
                      • 8
                      #25
                      Thank you Fergal but I finally managed to do it!!! I had not flashed by eurovox correctly. I had another file on my usb stick and I think it interfered with it.
                      For anyone else having probs, I found a really helpful thread by Bad Apple, I have pasted it below (not sure if I am allowed to do that by not sure how to get his or her permission, so I apologise if this causes offense but it was very very useful, so thank you Bad Apple!!)
                      Hi m8, here is the firmware for your box Digital Kaos - Downloads - EX1100 Sept25th Beta Firmware
                      Heres a guide and make sure the USB pen is formatted to FAT32 first.
                      Use winrar to extract/unrar the abs file needed to flash your box then.....
                      1). To update the firmware on the box follow below
                      2) place the usb pen drive into the eurovox,(with the power to the box off) power the box on.
                      3) Menu.........record......HDD FORMAT...format the usb flash drive..Power the box off and remove the usb flash drive.
                      4)Place the usb flash drive into the pc and drag and drop the updated beta abs file to its folder.
                      5)With the power to the eurovox off and all set up on the tv ready to view....Place the usb flash drive into the eurovox and power the box up.
                      6)menu......TOOLS.......UPGRADE BY USB.....SW..THEN RED BUTTON TO START THE UPGRADE...you'll see a bar move across the screen and the box will reboot..Job done..
                      REMEMBER,ALWAYS POWER THE BOX DOWN B4 REMOVING/INSERTING THE USB FLASH STICK TO AVOID COSTLY ERRORS.
                      SCANNING.
                      MENU.........INSTALL..........POWER-SCAN.....AND START THE SCAN...
                      __________________
                      ALL THANKS TO BAD APPLE
                      • villakiller
                        #26
                        if vm go with n3 surly that will kill them coz every1 will just ~~~~ off to sly or am i just thick
                        • nukeman62
                          • Feb 2010
                          #27
                          Hi Guys
                          Am new today, have lost quite a few channels since last week, thanks for all the info, I am going to try & get the channels back tonight to keep the daughter & misses happy. From Hartlepool and have a Max V 2008
                          Cheers
                          • STOCKTONDAVE
                            • Feb 2010
                            Just joined and having same probs with sky sports 1& 3 and a few others. Tried factory reset & scan but lost channels that said no signal. Will try earlier suggestions - Cheers
                            • puzzled2
                              • Feb 2010
                              • 9
                              #29
                              does anyone have a step by step guide on how you change the frequency manually for sky sports 1 & 3 please
                              • thered
                                • Aug 2008
                                • 4915
                                #30
                                press
                                menu-installation-user installation-your code prob (0000)-red button to update channels
