Channels Lost Teesside Eurovox 1100
the following is the latest firmware for the 1100
Digital Kaos - Downloads - EX1100USB_091217 FirmwaresigpicComment
hi just checking if anyone can help done a factory reset on the 1000 sl and then 1100 usb slim and the hd 7000 some boxes come back on and some of the boxes dont also my hd7000 did rescan but local region channels are missing like itv 1 northeast news is this because virgin are adding new hd channels to the bandwith please help cos some boxes including euro max dont seam to come on they just say no signal is they new firmware for this box aswell please help arrrrrrrrrrrrrrgggggg?Comment
I'm in Redar and simply doing a Deep Scan on my pvr1500 was enough to find all channels again, though i had to sort them all again. Didn't do a factory reset beforehand and it didn't seem to make any difference...many channels were duplicated though which is a ballache to sort for Favourite. Thought this was n3 armageddon this morning, so i'm just grateful it's back on at all...good luckComment
do you have have region channels comming on like north east news thenI'm in Redar and simply doing a Deep Scan on my pvr1500 was enough to find all channels again, though i had to sort them all again. Didn't do a factory reset beforehand and it didn't seem to make any difference...many channels were duplicated though which is a ballache to sort for Favourite. Thought this was n3 armageddon this morning, so i'm just grateful it's back on at all...good luckComment
All NTL areas in the North went off, that includes Redcar and Hartlepool.
See the following map for the areas affected:
hi download the www.chatterbox.com or www.bigmaq.com toolbars and they have a picture off a key on them go on that and you will see the codes for all areas and depending on what box you have just put the code in if you lose all your channels and its saying no signal erase all channels and do a factory reset and that should get them back on but if it says code updating and doesnt come on then it just needs code putting on if its a eurovox then press menu and yellow button that gets you on to were you put the code in i dont no how to do the others or you can download the latest firmware off here for what type off box you have but you will need a lead to do that okayComment
Yes that works a treat just have to put them all back in order for the second time this week wife just about ready to go for the full legit package thats her bingo money out the window only joking its a small inconvience.
got all my channels back with a deep scan using 6887... dont forget to delete all channels with factory reset or you will end up with two of each!! bad enuff trying to collate 1 set of the blighters ...many thanks to all that provided infoComment
hi mine had the same problem so all i did was restore the channels to factory settings then put it on m-maud 6887 and did a power scan and thay all came back.so i was watching an intriguing movie, and all of a sudden it went off, just black. so i was like, huh? every one was same. it then came up with the no signal. so i then did a fast scan, and it found channels again, but alot of them were just black, no picture or nothing, while some worked?
how can i solve this. thanks.
hope this helps dude....
