Channels Lost Teesside Eurovox 1100
  • dasteph
    • 1293
    #16
    Originally posted by endfleg
    teesside still off for me.. tried doing power scan with
    100MHz - 887Mhz
    9552, 6887, 6875, 6111 Mbaud
    640QAM (Modulator)
    Step 8Mhz (also tried 1Mhz)
    .. never found anything.
    did a factory reset and retried, still nothing
    tried doing deep scan on 6111, 6875, 6887 and 6952 - no channels found
    I don't even know what "TP List" is, but theres nothing listed in there and pressing "Search" does nothing
    can anyone help? (sorry, if this has been covered, but I can usually get channels back, this time I seem to be struggling)
    teesside is 6887 sybol rate, i lost channels last night did a deep scan on the above sr and got them back. (tp-- transponder)
    • dasteph
      • 1293
      #17
      Originally posted by paul.glenc
      sorry forgot to say.... 1100 usb
      the following is the latest firmware for the 1100
      Digital Kaos - Downloads - EX1100USB_091217 Firmware
      • skymanpaul
        • Mar 2009
        • 19
        #18
        hi just checking if anyone can help done a factory reset on the 1000 sl and then 1100 usb slim and the hd 7000 some boxes come back on and some of the boxes dont also my hd7000 did rescan but local region channels are missing like itv 1 northeast news is this because virgin are adding new hd channels to the bandwith please help cos some boxes including euro max dont seam to come on they just say no signal is they new firmware for this box aswell please help arrrrrrrrrrrrrrgggggg?
        • endfleg
          • 4
          #19
          no channels found
          my TP List is empty, signal quality 0%, how do i re-populate this list? HItting search doesn't seem to do anything at all :?
          • endfleg
            • 4
            #20
            they're back, just kept resetting and deep scanning, magically they apeared as i was nearing resign
            • jonnboy13
              • Feb 2010
              • 4
              #21
              I'm in Redar and simply doing a Deep Scan on my pvr1500 was enough to find all channels again, though i had to sort them all again. Didn't do a factory reset beforehand and it didn't seem to make any difference...many channels were duplicated though which is a ballache to sort for Favourite. Thought this was n3 armageddon this morning, so i'm just grateful it's back on at all...good luck
              • skymanpaul
                • Mar 2009
                • 19
                #22
                do you have have region channels comming on like north east news then
                • gr181
                  • Mar 2009
                  • 13
                  #23
                  just to let you know hartlepool n*l went off today.
                  • bon bon
                    • 6
                    #24
                    All NTL areas in the North went off, that includes Redcar and Hartlepool.
                    See the following map for the areas affected:
                    • davaw
                      • Feb 2010
                      • 14
                      #25
                      Originally posted by golf191
                      hi guys, im new to this site and all im after is a how to guide to get my teeside virgin channels back on... any help pleeaase.... thanks in adance x
                      hi download the www.chatterbox.com or www.bigmaq.com toolbars and they have a picture off a key on them go on that and you will see the codes for all areas and depending on what box you have just put the code in if you lose all your channels and its saying no signal erase all channels and do a factory reset and that should get them back on but if it says code updating and doesnt come on then it just needs code putting on if its a eurovox then press menu and yellow button that gets you on to were you put the code in i dont no how to do the others or you can download the latest firmware off here for what type off box you have but you will need a lead to do that okay
                      • downing991
                        got the toolbar but it says that it was last updated 12.10.2009 does this matter
                        • andy4
                          • 1125
                          #27
                          no m8 that is latest update
                          WIGAN ATH the BLUE BRAZILIANS
                          DWSTADIUM the theatre of SCREAMS
                          <<<<--------if i've been helpful hit the Thanks button
                          • seaformiles
                            • Feb 2010
                            #28
                            Originally posted by bigfella
                            saw on another forum u need to do a power scan? factory reset ?
                            Yes that works a treat just have to put them all back in order for the second time this week wife just about ready to go for the full legit package thats her bingo money out the window only joking its a small inconvience.
                            • paul.glenc
                              • 5
                              #29
                              got all my channels back with a deep scan using 6887... dont forget to delete all channels with factory reset or you will end up with two of each!! bad enuff trying to collate 1 set of the blighters ...many thanks to all that provided info
                              • ruffdog
                                • 6
                                #30
                                Originally posted by Rizolicious
                                so i was watching an intriguing movie, and all of a sudden it went off, just black. so i was like, huh? every one was same. it then came up with the no signal. so i then did a fast scan, and it found channels again, but alot of them were just black, no picture or nothing, while some worked?
                                how can i solve this. thanks.
                                hi mine had the same problem so all i did was restore the channels to factory settings then put it on m-maud 6887 and did a power scan and thay all came back.
                                hope this helps dude....
