HELLLPPPP!!!
  • dundee2k9
    • Mar 2010
    • 14
    HELLLPPPP!!!
    Hi folks,
    Need some help from you all. I have an ex1000sl and everytime i try to do a firmware update i keep getting the message, "waiting for the response from your receiver", when i press download, although i have everything connected correctly it never goes any further. Does anyone have any ideas of how i can get around this or am i doing something wrong. Thanks in advance
    FLY THE FLAGCHAMPIONS 09/10
    FLY THE FLAG CHAMPIONS 09/10
    Glasgow Rangers, Scotlands Number 1!
  • badapple
    • 2041
    Hi m8, try download to box again, have the box powered off, run download and when the message comes power on the box.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    • dundee2k9
      • Mar 2010
      • 14
      Thats not working either, it gives me a box saying the receiver wasnt detected and that i need to do it in boot mode?
      • smoggy
        • Apr 2009
        • 12809
        are you using a null modem cable only or in conjunction with a usb adaptor
        • dundee2k9
          • Mar 2010
          • 14
          i'm using the null modem cable in conjenction with the usb adaptor
          • smoggy
            • Apr 2009
            • 12809
            it looks like you need to install drivers for your adaptor
            if you go into device manager you should be able to see your adaptor connected to one of the ports, if you can't see it then it needs a driver
            • dundee2k9
              • Mar 2010
              • 14
              that could be the problem a when i put the software cd into my laptop it never picked up any cd i'll give it a go thanks
              • dundee2k9
                • Mar 2010
                • 14
                it's showing in the device manager as usb-to-serial comm port and when i go into the properties it shows as working properly so looks as if it can't be that
                • smoggy
                  • Apr 2009
                  • 12809
                  check which port it is connected to, it needs to be either 1,2,3 or 4
                  • dundee2k9
                    • Mar 2010
                    • 14
                    It's connected to port 9, how do I change it?
                    • smoggy
                      • Apr 2009
                      • 12809
                      in device manager right click on it and in the box that opens select port settings/then the advanced tab/in the Com Port number select a port from 1 to 4 that is not in use
                      • dundee2k9
                        • Mar 2010
                        • 14
                        tryed that but it's now saying no available com ports although i changed it onto port 2
                        • smoggy
                          • Apr 2009
                          • 12809
                          is port 2 being used by something else,you can try a different port as long as it is 1.2.3 or 4
                          time for bed good luck
                          • dundee2k9
                            • Mar 2010
                            • 14
                            the port is not in use, i tryed port 1 as well but no joy
                            • badapple
                              • 2041
                              Try this, safely remove the usb cable. go into device manager and set comm ports to comm 1. shut down pc. connect usb cable and power up comp but keep the box power off. run download again and power on box when message appears.
