the last code for ex1000sl
  • ninajayne
    • May 2010
    • 8
    Can anyone please give me the last workable code for the ex1000sl, my box is working ok at the moment, but after rescanning i ended up with a long list of channels of abt 3 of each one and i'd like to get rid of them.
    No sign of nag3 yet in my area and no new card as yet!
    Thanks to anyone who can help!!
  • BJTT
    • May 2010
    • 223
    Where about's in Scotland are you dobber ninajayne?
    If you are in the Glasgow area? I will give you the
    required keys! Yeah Later's BJTT It's A Hoops Social Thing!
    • ninajayne
      • May 2010
      • 8
      I'm not in scotland I'm in the midlands !
      • dasteph
        • 1293
        try a power scan that should reduce the number as deep scans find duplicate channels.
        • BJTT
          • May 2010
          • 223
          Hi ninajayne, where abouts in the Midlands are you?
          • BJTT
            • May 2010
            • 223
            Once you have done all of the above, hit "Exit" & Go back to the "Main Menu Window" then using the </>
            arrows, go to "Config" & In that cascading menu select
            "Clear Data" then select "Reset To Factory Default"
            then take a note of you Area Symbol Rate which is either "6.952 Or 6.887" then hit "Okay" to clear channel data
            & Reset back to factory default, then hit "Exit" back to
            "Main Menu" then go to selection box next door and
            select "Deep Scan" which normally takes about half an
            hour to do. Then once you have done all that, then go to
            the nearest wall and do this with your head. No in all
            seriousness, in actual fact you gain more channels by
            carrying out a deep scan. I know there is a lot of repeats
            in the list, yeah about six channel "Fives" and two or three
            of BBC 1's Etc-Etc, believe me with a bit of patience and
            time, you can edit the list by going through it in the
            "Channels Box In Main Menu" then select "Channel Manager"
            hit "Okay" & Type "0000" then select "Edit" in this cascading
            menu by pressing the "Green Button" then take your time
            going through the list, with any channels not worth keeping
            @ present, then use the "Red Button" to delete each one!
            Be careful going through the list and once you have finished
            editing said list, use "Exit Button To Save Changes" and exit
            out of "Main Menu Set Up" Hay Presto, Task Done!
            • BJTT
              • May 2010
              • 223
              If N3 has hit your Area, then the channels you should get back including BBC 1&2 England BBC1&2 Scotland
              BBC1 N.I. BBC1 Wales, ITV 1 London VH1, Cartoons
              & Comedy Channels & So On, As Mentioned Before
              A Deep Scan Picks Up More Channels Than A Power
              Scan.
              1 bbc1 scotland
              2 bbc2 scotland
              3 stv
              4 ch 4
              5 ch 5
              6 syfy channel
              7 disney channel
              8 national geo
              9 discovery channel
              10 alibi
              11 watch
              12 living
              13 living it
              14 eden
              15 dave
              16 blighty
              17 virgin 1
              18 bbc news
              19 bbc3
              20 five usa
              21 itv 2
              22 itv 3
              23 itv 4
              24 gold
              25 sky 1
              26 sky 2
              27 sky 3
              28 sky crime and investigation
              29 bravo
              30 bravo 2
              31 sky sports 1
              32 sky sports 2
              33 sky sports 3
              34 sky sports 4
              35 sky sports news
              36 quest
              37 more 4
              38 film 4
              39 dave ja vu
              & So On
              • BJTT
                • May 2010
                • 223
                If VM has sent you out a new card, it would be adviseable to remove your old card, and set up
                your vm stb with your new card in. switch on
                the said box and go to channel number 999.
                Make sure your "Forward Path Attenuator"
                other wise known as "The Spliter" is used.
                Point being, this is to let VM know that you
                are using their STB & By letting the said STB
                Register that you have recieved the new
                card. In other words, if there is no other
                VM user in your Area, it prevents them from
                switching/cutting off their tv service, in your
                Area, get the picture, boom, boom.
                Also, another good tip is, if you have go the
                new card, go through what I have mentioned
                on this note! Once you have done that, and
                the said STB is registered with the new card.
                Then leave the spliter in, and then set up your
                EX1000SL STB then go through the guide that
                I have given you, as regards to reseting your
                STB to Factory Default, Deep Scan, Editing
                Your Nagravision Window, & Then Editing
                Your TV Channels. you should get back all
                the channels that I have mentioned even
                with your spliter fitted onto your EX1000SL
                STB believe me, let me know how you get
                on with the said advice? Later's.
                • alexdc12
                  • 76
                  is it best to leave this splitter on ya eurovox or not?
                  • BJTT
                    • May 2010
                    • 223
                    hi alexdc12, if you have received the new vm viewing card from vm. Then it's best that you set up your vm
                    S.T.B. with the said new card in, and obviously the spliter attached to the cable and then go to channel
                    999 and let the vm S.T.B. register the new card with
                    vm. If you don't go through this procedure, and there
                    is no other vm cable customers in your Area, then you
                    run the risk of your Area been shut off. To be honest
                    with you, I have another opinon about this matter which
                    I will post in due course. If you have not received a
                    new viewing card from vm? Then you can still go through
                    the said above procedures with your spliter attached to
                    your cable and your Satellite 'F' Type Socket To Coax
                    Plug Adaptors. To be honest with you, with vm switching a load of channels over to N3, I don't think it makes
                    any difference, in other words, your FTA EX1000SL
                    STB will still pick up the same channels after a deep scan, yeah later's!
