hi got box downstairs normal virgin with card, but then upstairs i have a normal virgin box in 1 room, internet in another and a arnet box in mine, trouble is i am always havin problems with whichever box goes in my room. could it just be the lead from the splitter to the box is not as good as the ones virgin supply us with, all boxes and internet work good in every room except mine
av i got to many cable boxes
It might be a loose connection in the splitter or maybe a bad f connector. Check all connectors are snug
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'. -
Are the leads on the same splitter ? The signal might be reduced because of this. Try taking one of the boxes out and see if it makes a difference. You may need a signal booster. If your going to buy new cable might as well cut the ends off the one you got and try new connectors first and see if that helps
The panel has quite simply found 'no evidence' in support of allegations of 'exceptional levels of drunkenness, ticketlessness or violence among Liverpool fans' and 'no evidence that fans had conspired to arrive late at the stadium' and 'no evidence that they stole from the dead and dying'.Comment
Whats the trouble you are having putting the f/w on mate you need both the f/w and the loader.
Digital Kaos - Downloads - Kryptview Firmware 291108
and this is for the loader.
Digital Kaos - Downloads - Arnet Kryptview Loader
and here's the loader instructions
Digital Kaos - Downloads - Arnet Kryptview Loader InstructionsSometimes a slow gradual approach does more good than a large gesture.Comment
Is it just sports channels m8 or all premium channels. What problems are you having flashing firmware. There is a guide to download in the downloads section and all the latest firmware
Why don't you have another go using the guide. Theres always someone to help you out if you get stuck m8
