Which Combo box if any
  • Scorpio53
    • 11
    I used to have The Box USB until it turned into a brick after N3 upgrade.
    I'm looking for a reliable Combo box but not sure where to post should it be in Cable section or Satelite section.
    Are there any boxes that can cope with N3 I have VM cable and a 80cm satelite dish which can get all Sly channels and more.
    I've herad the way to go forward is some kind of combo box with a LAN connection does the Kryptview have dual inputs.
  • ramjet
    • 2995
    you wont find any combo box that does satellite and cable , apart from the freebie cable channels
    the only 2 that work on cable using ethernet connections are the sv7 and krypt a780 ( there are older boxes that work with addons etc )
    both need the internet , the sv6 and sv7 is extra for the service too
    the HD box that did work is the sv combo , but thats used on sat only now
    no the krypt doesnt have dual inputs , nor the sv7
    no box can cope with n3 unless you use an ethernet connection for cs
    • cactikid
      • 12017
      blade combo but as said its cs on both sides.
      • Scorpio53
        • 11
        Does the Kryptview need anything else other than LAN connection i.e do I have to pay a subscription to use it as well?
        I've heard Sly don't use N3 so would I be better looking for a satelite receiver and use the 80cm Ross Dish feed I can pick up Astra and a few others as well or does that still involve subscrining on top of price of the receiver.
        • Shady
          Shite Link King
          • Dec 2010
          • 6404
          kv just needs lan and connection to cable network.. no subs
          sly dont use n3 no, they use nds encryption, and YES u would be better with a sat system.. more than likely a sub involved with sat
