How to Make a JTAG cable
  • djquwarg
    Why I can't download the file?
    • PremierD
      TAMINATOR
      • Jun 2009
      • 13223
      #47
      As always mate ..... why the rush, you register just to be able to get a FREE solution and then your only post is to complain......
      Take a walk round the block ..then try again .........................
      • dancha
        how hard is it to make one of these?
        • cogeanu
          jtag cables
          Originally posted by strat
          Does anyone know where i can purchase one of these cables...?
          you can also buy the cable from here:
          hxxp://www.easymg.com/
          or from here:
          hxxp://www.diygadget.com/
          hope it helps
          • yohoworker
            #50
            for what reason this is harder than it looks to build.
            • Flash2003
              #51
              Originally posted by default
              for some reason this is harder than it looks to build.
              can i use this for boot repair my Elap Thallis? thanks
              • Flash2003
                #52
                Originally posted by zeuss_net
                This cable is parallel-jtag?
                This cable is parallel or serial-jtag?
                • lastclass
                  • Jul 2010
                  Originally posted by SEAZURE
                  CAN I USE A HD IDE RIBBON CABLE FOR THE JTAG
                  yes thats no problem .. just made one and works fine
                  max 10 cm long cables
                  • nachotico
                    • Jul 2010
                    does it work with cable modems?
                    • digitaly
                      • 55
                      #55
                      Originally posted by Flash2003
                      how do i get to download info for serial(DB9)-jtag cable ?
                      This is for the max 232 cable if it helps!!!
                      • HyperTurtle
                        • Apr 2010
                        • 7
                        #56
                        dm500c jtag
                        what's the best cable to use to make the jtag cable
                        • stifiling
                          • Nov 2010
                          #57
                          is this to make a parallel or usb?
                          • KenshinPT
                            • Mar 2010
                            • 408
                            #58
                            Originally posted by compyprog
                            I must make this short right?
                            As someone said before: "don't exceed 10 inches."
                            Did it help? Push Thanks below
                            • BlackHatCracker
                              • 7
                              #59
                              Here is the full link on how to do it... The other link images was good, but missing a few parts in it... http://www.tiaowiki.com/w/Make_a_Sim...FTA_JTAG_Cable I hope that this helps those who were trying to do this. I will attempt to do this and let you know how it all works out.
                              Last edited by BlackHatCracker; 9 January, 2011, 05:06. Reason: corrected linking issue
                              • Praet0ri4n
                                Originally posted by digitaly
                                you need 5 useful post before downloading... Have a look around the forum e share some knowledge ;-)
                                Weird policy but if nobody minds, I place this reply here And btw, thanks for the custom JTAG cable manual, as far as I will be able to download, i will take a look
