i have been given a box but it has no name on it so i dont know where to start to flash it. it has a sti-5518 chip inside and a samsung tuner, on the front panel there are no buttons just a window about a inch across with a green led on it, it also has 9 small dents on the right spaced like 3 up and three across. it has also got a viewing card slot on the left hand side behind a drop down door, its about the size of a freeview box and it is silver in colour. anybody any ideas? your help is much appreciated, thanks in advance
cable box
take some pics and post them on here - someone might recognise itComment
cable box
the guy i got it off said it is a starview box but im a bit sceptical, can anybody confirm that it isnt a starview box, if so ill have to borrow my mates camera and post a couple of thumbnails.DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
think it might be one of them UFO's that have recently been recently reported in the tabloids. Is you m8 green and a bit strange looking?Comment
@mdt have you taken any pics of this box yet.. have a look at this link and see if it looks like your receiver, it does have the chipset you speak of but says nothing about the tuner make etc. Before we can progress this we need to decide what box you have..
the box Cable Receiver - Goodvb Technology Co.,Ltd Satellire Receiver
If it is not that one then please type in 'cable receiver' into google and then select 'images', go through the images until you find an image of the your box then come and advise us...Comment
I found a description and specs about your box but could not find a name for it after quiet a bit of surfing.
Product Description
1) Main market: Europe 2) Size: 230 x 200 x 30mm 3) Weight: 1.4kg
Product Specification/Models
Features: 1) Fully DVB-C & MPEG-2 compliant 2) More than 100 channel parameters 3) More than 200 TV program and Broadcast parameters 4) Electronic program guide 5) Volume adjustable and save each program's volume separately 6) Super definition screen picture and high fidelity digital stereo output 7) Automatic, manual or easy installation 8) 6MHz, 7MHz and 8MHz software settings 9) Teletext output, compliant with ETSI / EN300 472 10) 2500 channels of TV & Radio Programmable 11) Software upgrade via RS-232 serial port 12) Multi-language audio 13) Subtitle reception support 14) Parental lock control 15) Standby with low consumption 16) Time adjustment
Here is the site i found it on
cable box
thanx for ur efforts pal, im one step closer now. is there anybody else out there who might know what patch i need to put in this stb, maybe its a clone of a named box and uses the same software?, any help is greatfully appreciated. thanks as always and congrats on an excellent forum.
cable box
seeing as nobody seems to know what patch to put in this box, is there any way to put the keys in manually cos it has already been patched once before but i dont no how to get the key edit menu open. im presumeing that there is some kind of 4-digit number or some hidden menu. has anybody got any ideas concerning my question or is it just fit for the bin?DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
