Have I missed something out?
  • nowuckinfurries
    • Aug 2009
    • 111
    Dm800HD Sat box.
    Factory reset.
    Replace Sat tuner for new Cable Hd tuner
    Installed dvbsnoop
    Installed AutoBowKs C2
    Installed local service file C2 ( North west )
    rebooted
    Now here's the issue not getting any chanells i.e bbc 1 to enable me to put on chan to use autoBowKs. Does this point to an iffy new tuner or have I missed something?
  • WOODWARD395
    • Apr 2010
    • 628
    Have a look here m8 I had the same problem******* if you look at the images at the bottom images it gives you tuner set up I tried everything to get channels until I just copied the tuner set up just replace your Net ID for your area and frequency mine for Manchester is 171mhz hope this helps. I used autobouquet maker as this has virgin uk in settings.
    Originally posted by nowuckinfurries
    Dm800HD Sat box.
    Factory reset.
    Installed dvbsnoop
    rebooted
    Last edited by satsmo; 5 July, 2014, 22:37. Reason: Removed link to forum of similar content - Please read our rules!
    Education is not the learning of facts, But the training of the mind to think
    So hit the thanks button if I have enlightened you.
    • nowuckinfurries
      • Aug 2009
      • 111
      Nope thats not worked for me.
      Anyone got a Knowsley cable bowK?
      • WOODWARD395
        • Apr 2010
        • 628
        silly question maybe have you put your net id in before doing an autobouquets maker scan. NetId - 40965 (a005) - Knowsley 1
        NetId - 40966 (a006) - Knowsley 2
        • nowuckinfurries
          • Aug 2009
          • 111
          Am I reading this wrong.
          I thought I had to have it selected to a current channel i.e BBc 1 , with Dvbsnoop installed before using auto bowkS?
          • nowuckinfurries
            • Aug 2009
            • 111
            and my net id only allows a 4 digit input
            • WOODWARD395
              • Apr 2010
              • 628
              Have you managed to sort it yet m8 if not might have a solution might work as I kept scanning over and over again getting no channels and every time I put the correct frequency in I got no channels.
              Do a automatic scan in frequency put 466 do scan should show on screen I believe trying to find frequency you have to watch the screen it should say on most frequency failed but on about four frequency's it should say frequency ok write them down when finished it should scan after if no channels found then do another automatic scan but put each frequency in and do a AUTOMATIC scan again if no channels found put the next frequency in and try that and so on hopefully you should get channels found on one of them if you get a frequency that is say 170.5 you can enter 171 if you cant enter 170.5.
              this worked for me as for some reason the frequency was out.
              some people will say the normal scan should put the frequency in and find the channels but mine would not I am no expert but it worked for me.
              and yes I done a network scan and net id correct but this is the only way I could get my channels.
              Last edited by WOODWARD395; 6 July, 2014, 16:02. Reason: wrong typ of scan entered
              • WOODWARD395
                • Apr 2010
                • 628
                Just updated my image and scans perfectly now and get all channels no problem.
                • anthmatthews
                  • Feb 2013
                  • 100
                  What image are you using Woodward?
                  • WOODWARD395
                    • Apr 2010
                    • 628
                    I am using the vix image appolo 15 now had problems with update 12 and 13 scanning cable for some reason read on another forum some were having the same.
                    vix images
                    http://www.openvix.co.uk/index.php?dir=
