Signal quality rodds
If a want to spilt my cable feed and run it to a second box how do I prevent loss of
And even sometimes the yellow brick wont work as I have found out in the past. Some people are at the assumption that picture break up is due to weak incoming signal. It can be even worse if it's too strong a signal. Bestbet, ring them up and get an engineer out , just say your box or bband hit or miss. They will check it and get it right.Comment
you can just split it and go from there if you get break up and your original picture was ok it is likely your signal is too weak to run two box's. you can install the konig booster which more than likely will cure your problem.
if you get any problems come back and we can resolve your issue for you.Education is not the learning of facts, But the training of the mind to think
So hit the thanks button if I have enlightened you.Comment
