If a want to spilt my cable feed and run it to a second box how do I prevent loss of
  • rodds
    • 55
    Signal quality rodds
  • cactikid
    • 12017
    you cannot prevent loss even with the best cable and splitters,if signal is weak people have used the yellow brick [ konig booster ] to improve viewing.
    • loncell
      • 625
      And even sometimes the yellow brick wont work as I have found out in the past. Some people are at the assumption that picture break up is due to weak incoming signal. It can be even worse if it's too strong a signal. Bestbet, ring them up and get an engineer out , just say your box or bband hit or miss. They will check it and get it right.
        Originally posted by loncell
        Bestbet, ring them up and get an engineer out .
        Just to add to that make sure you REFUSE to press the thanks button, no matter who helps you out in your threads.
        • WOODWARD395
          • Apr 2010
          • 628
          you can just split it and go from there if you get break up and your original picture was ok it is likely your signal is too weak to run two box's. you can install the konig booster which more than likely will cure your problem.
          if you get any problems come back and we can resolve your issue for you.
          Education is not the learning of facts, But the training of the mind to think
          So hit the thanks button if I have enlightened you.
