help i am gonna throw it !!!
    Hmm not upto date on this box but as a guess does it have the latest firmware on it ?
    • 11dicky
      • Jun 2009
      • 16
      #17
      smirnoff i think the answer is mhz going from 300.000ish - 826.250.
      • wilf
        • 1618
        #18
        Originally posted by 11dicky
        its new bulldog so i haven't got it working yet. i know i am probally missing some thing really simple, but i can't figure it out. i appreciate u all taking the time.
        if you got a the cabling set up correct it should be at least picking uo free channels
        • alan truey
          • 81
          #19
          digivox xl
          have you tried the manuel scan and then a few boxes down were it says disabled change 2 enable as that has worked for me!!
          • 11dicky
            • Jun 2009
            • 16
            #20
            yea it has the latest firm ware on it, the cableing is correct triple checked it about ten times now . i had the free channels once just can't seem to get them again.
            • smirnoff_rules
              • 8603
              #21
              no m8 not that, the main one 6.952 or the other one
              • 11dicky
                • Jun 2009
                • 16
                #22
                hi alan, gonna try that now brb .
                • wilf
                  • 1618
                  #23
                  maybe a bad flash i would do it again if it were me
                  • fay28
                    • 66
                    #24
                    hi m8
                    go to menu/system information/ key in 1004/select set default keys, press ok and exit out to rescan.
                    shoulddo he trick
                      You'll get there sooner or later m8
                      • 11dicky
                        • Jun 2009
                        • 16
                        #26
                        6.887 msps is that the one?
                        • smirnoff_rules
                          • 8603
                          #27
                          try 6.952 m8 .. not sure wot area u r but it makes no odds to try it
                          • 11dicky
                            • Jun 2009
                            • 16
                            #28
                            tried that fay thanks tho.
                            i have tried that too wilf thanks
                            i know i will do trial and error thanks bulldog
                              If you've tried everything suggested including reflashing the box it may be a dodgy box you got m8.
                              • 11dicky
                                • Jun 2009
                                • 16
                                #30
                                yea i am begining to that to bulldog
