DigiVox XL
  • lmfcobra
    • Mar 2009
    DigiVox XL
    Hi can anyone help pretty new to all this i have a digivox xl is there anyway of getting the on demand channels,pls help am stuck...
    lmfcobra
  • cloudnineuk54
    • 530
    in short no,you can only get box office mate
    • cactikid
      • 12017
      these boxes do not have talk back so you cannot order anything.
      • JimX
        DIGIVOX XL -I'm now Missing Sky Box Office (was on 1700 !!)
        When I first got this box I eventually found Sky Box Offive on 0242 TV 1700.
        However, it now says 'Scrambled or Bad Channel'
        Everything else appers to be there working Ok, and I have read all the Tutotials Re-scanned Factory re-set the lot.
        The Nagravision is 'On' and the Key EMU is 'on' on the CAS SYSTEM Screen !
        I have tried re-scanning as Automatic AND Manual and nothing seems to unscramble this channel (and I can't find it Sky Box office on any other Channel
        In short I'm stuck, and need some help with this despite reading all the posts.
        • coolnas
          lmfcobra
          I got Digivox XL and I can not get Sky Sports1 and Sky Movies Actions but ALL Channels are coming fine apart from these two - Done all but nothing has worked so far..any help please???
          • coolnas
            I have got Digivox XL, which is working perfectly very well and I got all Channels without any problems what so evr: However I have no Sky Sports 1 for almost 2 months and NO Sky Movies Action for almost 1 month, How can I get them back? I have done all I could up-dated Codes again and done all scanning but nothing has worked...Please HELP
            • mikestonier
              i have just had my digivox xl today and i am unsure on how to set the thing up its not quite as simple as plugging it in and the channels appear is it?? any help appreciated thanks
              • cactikid
                • 12017
                channel movement happens and you lose channels,factory reset first,0000 to delete,remove any splitters first before you auto scan your provider and emu to on they should work now.
                • cactikid
                  • 12017
                  is it the ordinary xl or xl usb as they are different boxes and different firmwares and all info in downloads under starview.
                  extra thing to add after factory reset and when deleted power off box at back for a min/on always scan direct from wall socket.
                  • scotlandboy
                    • 24
                    I have got no longer SKY Sports 1 and Sky Movies Action anymore, can you please help Sir? Please?????
                    • satsmo
                      • 6397
                      As sated above, press factory reset in menu. Scan again on your provider ID. After scan completes, press menu - system info - press OK - type 1004 on remote and turn on emu.
                      Exit out and channels should be back. If you had them sorted you will need to sort them again once you have carried out a factory reset.
                      • tomharvey93
                        • 10
                        what is better the make Digivox or Eurovox ? im new to this and im undecided on which one to buy. i have a budget or 90 quid
                        • cactikid
                          • 12017
                          before you buy any box read up on nagra3.
                          • goosie64
                            many thanx
                            followed your advice ,everything back as before .thanks again
