Sky Sports 1 missing
  • Mic260
    • 209
    I have tried a Factory scan on my starview but still can't get Sky Sports 1, Sky Sports News and Sky Premiere
    Does anyone else have this problem?
  • chris18blair
    • 15
    This happened on my Eurovox. A fast scan done the trick.
    • Mic260
      • 209
      Hi chris
      I have a Starview, so can only do a Factory Scan or automatic Scan
      Where are you based and were you also missing exactly the same channels?
      Best wishes
      • l4rrybr0wn
        • 7
        Hi Chris, I have exactly the same channels missing. I've tried a factory reset and a default key reset. Then applied the new keys, emu on and re-scanned with no splitters and still no joy. Hopefully, someone on here will know the score.
        • Mooley
          • 82
          Maybe get the specific frequencies for those channels and do a manual scan maybe they've moved.
          • torquemada
            • 7
            I have the same channels awol, but my dad still has them, he lives in the same area as me (ex telepest).... hmm bizarre!
            And the Lord said "Torquemada come Fourth" but i came Fifth and won a teapot!!
            • l4rrybr0wn
              • 7
              Anyone know the frequencies for SS1, SSS etc. must be worth a go
              • aftermath
                • 4345
                what area ? also is it ex TW ?
                • l4rrybr0wn
                  • 7
                  I'm in London, ex c&w mate
                    Originally posted by Mic260
                    Hi chris
                    Best wishes
                    press default key first. then rescan your box m8.
                    • l4rrybr0wn
                      • 7
                      Hi maca, I tried that mate. is there a certain order to to what you do then? I done a factory reset, then set default key, then i put the new codes in and scanned or should i scan first, then put in the new codes and turn on the emu?
                        ok m8 you should just enter keys then save them. make sure you have right provider when you enter them.
                        also make sure you turn key emu on after you scanned you r box. 1. default key. 2. rescan. 3. turn emu on. then exit out to tv.
                        • torquemada
                          • 7
                          The plot thickens..... I run a DM500C (original) and an old Dbox2, the channels are missing on the dreambox but they are ok with the Dbox. Now im thinking its signal issue as my dreambox feed is split to my modem and VM box, but my Dbox has its own seperate feed.
                          Ill get a hold of a booster and see if this solves the problem, does anyone else have any ideas?
                          • Fergal
                            • Aug 2008
                            • 1007
                            Swap the boxes (dm and dbox) around if the dm then works you know its a signal issue and a slx1p booster might help.
                            • l4rrybr0wn
                              • 7
                              Thank maca! will give it go mate.
