Zgemma problem
  • tweenage
    • 60
    Zgemma problem
    Right I just got a zgemma h2h put vix on it , and getting low signal rates on all Channels , nothing is clearing , and keep getting service not found , sid not found in pat , anyone got any ideas , net Id is correct and am at a loss now
    Many thanks
  • plasterer
    • 1631
    Low signal levels is OK.
    29 percent mine runs OK on.
    Recheck net ids
    Select vm from providers and run auto bow k
    Let's know results. ..... paul
    If your Happy with the Help push the Thanx button
    PAUL
    • tweenage
      • 60
      Have done auto scan and get 397 channels , on my Id 41050 which apparently is correct even though area name is wrong , when I do manual scan , I only get 3 channels , :-/
      • plasterer
        • 1631
        wot area are yu in.
        What net id are you useing
        Are you getting Free to air channels
        .............Paul
        PAUL
        • tweenage
          • 60
          Now getting a few premium channels clearing , others say something about Sid not found in pat , area code I'm using is 41050 , but picked up a genuine box and it's showing net id as 41051 , but that's no where near my house , am going to try it later when get home
          • tweenage
            • 60
            Would if code was wrong , only give me a few premium channels and create that error on others ?
            • lincsat
              • 1228
              You have put the correct NetID in the ABM and not just in the tuner config? If a subscribed box works with a certain area code, then use that.
              • P&D
                • 2684
                If you give us clue what area you are then we can give you the correct net ID
                or is this a guessing game ?
                Needed to pick up channels.....correct net id & correct symbol rate
                we can only guess at these without help
                Example Manchester...............
                Manchester 1 NTL ex C&W 41040 6.887
                Manchester 2 NTL ex C&W 41060 6.952
                2 different net ids & 2 different symbol rates but the same place
                • tweenage
                  • 60
                  Yep problem I have , I live in Shepherd's Bush , which is 41050 , but when I use that id I only get a few channels clearing , i.e. Sky sports 5 , but ss 1-4 show as no pat In sid , and yes but the Id into Abm and tuner , it's very strange , apparently you either get premium channels or you don't , it's shouldn't decide to just give you a few , like I don't have normal channels 1-4 but have channel 5 :-/ , thinking maybe cos virmin split off the neighbours feed , i( as my cable couldn't be traced ) it's causing some kind of conflict , what do you think ? But they supposed to be coming on Wednesday to pull me a new cable to my house , maybe that will solve the problem , but not holding out much hope
                  Regards
                  • tweenage
                    • 60
                    Sheperds Bush NTL 41050 666.750 6.887 , am I supposed to do anything with the 666.750 6.887 ??
                    • P&D
                      • 2684
                      Go in to your tuner settings net id 41050
                      provider to scan VM UK 6887
                      then do a manual scan you should get the channels
                      I think you can also set this up in ABM as well..in the same way
                      • tweenage
                        • 60
                        I don't see them numbers , I got options pure , bruteforce , no numbers visible , I scanned on pure :-/
                        • tweenage
                          • 60
                          On my symbol rate , on tuning info it says symbol rate6952 -auto , maybe there lies my problem
                          • tweenage
                            • 60
                            Somehow managed to switch rate , had to do manual scan and now all working , got lots of duplicates , can I run bouquets to clean it up
                            • P&D
                              • 2684
                              Yeah mate I think so......I don't use ABM mate
