f lines and c lines ., wots that m8 and wot splitter would the cables go into ( not vm cable )
An f line is what you put in your sever for every client who want to view channels from your sever and in return you send them a c-line which they can put into the cccam cfg file in their receiver in order to login and view the channels.
so just for educational reasons ... wot could u need and wot type of cost for home use ?
a server is a pc that can handle , manage and provide incoming and out going connections
every dreambox is already setup to be a server you just gotta configure it a little
when people talk about pc servers
it just means that instead of killing that little 250mhz cpu to handle all your connections you install linux debain and cccam on a pc to handle the connections for you and just use the reciver as a client to that server
this is where usb card readers come in. you plug usb readers into your debain , which will then supply the boxs
its very simple really
so all the box has to do then is open channels and mange 1 just 1 connection instead of many which will in turn slow your box down and make unstable
Qualified Jedi Master
Virgin VBox
x2 PS3 JB FW 3.55
X2 Wii 4.2E soft modded
4x DM500S + JADE PLI
Openbox HD S9 & S10
DM800 PVR + BLACKHOLE
Dedicated Linux Debian Server
1.2M Dish Sky UK, Viasat, Sky IT ,JSC ,Tring+ Cards
90cm Fortec Star Motorized Dish
Virgin 50mb Fibre Optic Broadband
Xbox 360 Samsung LT 2.0.1 No AP25 + Liton LT 2.0
Microsoft Approved and Certified OEM System Builder
Subaru Impreza GB270 Owner http://online-console.com
1. As stated in a previous post you need a box to act as a sever.
2. A subscription
3. Broadband connection
You can easily weigh up the cost from here.
For sharing 4 boxes inside your own home like smirnoff,
I did not think you would need even the "Broadband Connection",
You would only need an old Router with each of the boxes clonnected to it & having it's own internal ip address configured on an internal network, just like you would connect pc's laptops & network printers ect.
All the boxes can then talk to each other,
once the cs config files have been adjusted so that the one box "with the card in" sends the card info to the other 3 boxes.
thats right mate yeah if ur sharing your own viewing card internally you would just need a server a router and clients being the boxs , net is only required when sharing with external peers
Virgin VBox
x2 PS3 JB FW 3.55
Openbox HD S9 & S10
The Only Difference between the server & client box, is that the server is the one with the card inserted.
The rest of the configuration, apart from a few digits is the same.
CardSharing Setup:
Server:
Dreambox, Setup With Cam (CCCam/Newcamd) + Card
Client
It might sound complicated to setup, however it really only takes a matter of minutes.
If sharing Sky for example, you need the card & the box key, which you can easily read from the information menu on the sky reciver.
Then you need to install & setup the cam, most images will auto install the cam and another simple program with a few clicks will setup the config file.
Side Note*
The Server, does not have to be a dreambox, if you want to be more technical, you can use your pc or other hardware + card reader setup.
i wouldnt bother using the dreambox to serve, just get a shitty pc and ulpoad ubuntu server newcs and cccam and its happy days, the latest sly cards share fine so dont doubt the new nagra will be any different, nds is a far superior encryption system to nagra.
