hack for N3 , is it legit ?
  • southpaw
    • 2233
    Hi guys , just on another forum and some dude posted the text below , just after any thoughts ,
    this method worked in eurovox max - black , try on others may be it will work.
    step 1 , there is a card slot on eurovox max- black. currently its empty as software is doing the rest of the work.as we know that vm has changed to n3 we have no other alternative then to use a n3 card with the same clone rate as the new ones.
    step 2- now closely look to the channels it will clearly says scrambled but you cant get the picture ...yes why? this is because vm have only changed the encryption cycle on the new cards so although your channels are scrambled to your box ur box will not be able to read the symbol rate as this has been transferred to the chip section in your new vm card.before all were thrown at once but now they are divided as soon as it reaches the box . this is beacuse they have used Mediaguard SECA 2 encryption.good news is that the vm have not fully adopted the n3 encryption all they have done is split the symbolrate for a box and the chip in the card.(clever huh)
    its just too expensive to change over. The decryption unit is either integrated into a receiver,chipped card or available as a conditional access module (CAM), or as one of many encryption schemes supported on a CAM emulator.
    so here is how we beat it .
    remember the vm card you got? yes now you need to phone them and ask them for another card saying that you never received it by post. once you do that wait until the new ones arrive . now you must use a splitter and have a eurovox box and vm box attached to it. insert the card to vm box and the one which you had (the one you told them you never received it)to the eurovox . please note one of the card will obviously not work as that would have been cancel by vm before issuing you with the new one but that don't matter as the chip in the old card will still have the delay mechanism used by n3 working . let the vm update the channels ...in eurovox do a power scan ..there you go . it was stupid of vm to split the
    access system as it can
    be practically broken by image processing algorithms that rearrange
    the lines of a eld based on statistical properties of typical TV images.
    With some knowledge about the limitations of the scrambling hard-
    ware one can reconstruct the scrambled TV image in real-time without
    knowledge of the cryptographic secret stored in the subscriber smart-
    card.
    Draft Technical Report $Id: nagra.tex,
    1 I
  • maxi1968
    • 417
    read it myself about ten minuits ago seems feasable but until the method has been tested and proven then i will remain weary.
    • southpaw
      • 2233
      i aint no expert but the author does seem clued up in the technicalties and terminology of it ,
      • chris31560
        • Feb 2010
        • 912
        hi would this methard be possable with a dbox or is it just erovox boxes??... ps providing it workes...
        A LITTLE THANX GOES A LONG WAY
        • maxi1968
          • 417
          it looks feesable however as i have stated until its been proven .on another note if it does work will it be possible to get a dump from the un subed box?.i posted this on another site....my pal has a dbox 2 hooked up to his sly dish an gets most channels i thought he was cs but to my amazement he wasnt ,then at his request his neighbour came in and invited me to his hose to see his set up ,it was the same no cs.i am going to see my pal at the weekend ,i will be getting him to write down exactly how they doo it.
          • batman44
            • Mar 2009
            • 276
            No card slot on Eurovox max v 2008 (Black). Net ID split with box & card? To simple can be split with emulation software. Not gone over yet so cannot test, I have my own theories to try.
            Keep calm carry on.
            • david alton
              • 105
              Pull the flap open on the front right hand side 2 slots and something else the bottom slot has a functioning card reader in it.
              • smoggy
                • Apr 2009
                • 12800
                it is being discussed on another forum
                sunrise and the coder say its a load of Bulls**t
                a lot of people will know how clued up these guys are so what they say is good enough for me.
                • maxi1968
                  • 417
                  like i said wait and see if it is proven to work.chill dont get worked up over it all.lifes too short and the summer is on its way .happy days.
                  • southpaw83
                    • 360
                    is it ~~~~
                    snowing in glasgow
                    • maxi1968
                      • 417
                      aye get the suntan lotion oot.bloody scottish summers.
                      • lfc4life
                        Sports Nutter
                        • 3200
                        there like indian summers
                        IM SORRY but i will never have any sympathy for maggie thatcher .... the bitch
                        I WOULD STILL LIKE TO SAY MY HEART AND RESPECT GOES OUT ALL BRITISH AND ALL ARMY TROOPS FIGHTING THE TERROR WHICH STILL BREEDS IN THE WORLD!! YOU HAVE AND ALWAYS WILL HAVE MY UTMOST RESPECT !
                        YNWA!!!
                        JUSTICE FOR THE '96"
                        "People say football is a matter of life and death. I'm disappointed by that approach, I believe it is much more important than that - Bill Shankly" -
                        YNWA
                        • jumpinjo
                          • 869
                          Originally posted by smoggy
                          sunrise .
                          he wouldn't know his arse from his elbow ffs
                          • smoggy
                            • Apr 2009
                            • 12800
                            everyones entitled to their opinion
                            as he has made available firmware updates for certain boxes I think he must know what he's talking about on this subject.
                            and as I know ~~~~ all about that side of it what He says is good enough for me.
                            as I haven't a clue who you are maybe you could enlighten me on why you made that statement.
                            • smirnoff_rules
                              • 8603
                              l also read that if u phone and say your card hasnt turned up they send a replacement but also turn the n1 stream back on untill the new card comes .. so that might be all thats happing here
