Digivox Firmware v3330 for T (MMDS)
  • satsmo
    • 6397
    #76
    Take a look on page 1.
    • villan86
      • 4
      #77
      Hi lads new to this site but about to drop kick my digvox t out the window
      When first got it had some trouble flashing it but eventualy managed it when i had right com port open.
      Since codes changed cannot flash new firmware at all.
      Tried everything can think of and just get pop up msg "flash update failed"
      Any ideas ??
      • jasbo7
        • 1432
        #78
        Hi Villan86 welcome , you should look at the first page of this thread
        • villan86
          • 4
          #79
          Hi jasbo7
          Thanks for reply have read it but not sure relevant
          I have flashed box before and worked once correct com port was open before i did that an tried it would just stay endlessly on o% progress without communicating with box.
          Now my problem is that it is communicating with box but just coming up "flash update failed"
          Ive tried two dif pc and operating systems?
          Should i just keep trying a hard boot flash and hope it works?
          My box down since dec 20th
          Thanks in advance
          • cactikid
            • 12017
            #80
            u have flashed before using same cable yes.have u,have u unzipped file,have u tried all 4 comport settings?
            • villan86
              • 4
              #81
              Yes have unzipped it is now showing on desktop with vlc symbol.Have tried all four com ports.
              When using Pc at home with xp rather then laptop with vista i am using the null modem cable without a usb serial converter and still no joy.
              Appriciate any help is dragging on a bit.
              Thanks advance
              • hopper28
                • 119
                #82
                try setting com port to different baud rates 9600 or 19600
                • villan86
                  • 4
                  #83
                  Will do tonight.
                  didn't have a clue wat all these settings were or did so left alone.
                  Thanks for suggestion
                  • paulstacey79
                    help digivox t
                    I am trying to downloaad firmware but am not allowed?
                    • cactikid
                      • 12017
                      #85
                      have u used that null modem cable before as people get wrong cable and they dont work.
                      • artman
                        • 4
                        #86
                        Whats what?
                        Hi, I have a digivox T and was able to sort out by manually entering key. What I cannot understand is the "firmware"**"Flash"
                        Can you explain what they mean and what they do. As you can see from above I am new to all this and am trying to get my head around the lingo
                        • tdtd80
                          Thanks for download
                          Originally posted by Devilfish
                          Here's the latest firmware, (22/12/08), for the digivox T receivers for Ch*rus MMDS areas.
                          Digital Kaos - Downloads - Digivox T MMDS V3300
                          thanks for the download new guy in town,,,,,,
                          • folex9
                            #88
                            mmds
                            Hello, i have bought a digivox t, i do not have any Ch***s aerial. Just a basic aerial to pick up regular national channels (R*E 1 & 2, TV 3 etc). This is considered mmds signal?correct? and will this be acceptable to operate the box? i would appreciate if someone could get bac to me on this. Thanks
                            • cactikid
                              • 12017
                              #89
                              no mmds is a special aerial so wont work as it needs to be powered up.
                              • metalgear2k2
                                • 12
                                #90
                                Hi guys, im brand new to all this and was wondering if I could get some help. I got a Digivox - T and am in clonmel on cable chours, I got a cable with the box but cant get it to connect to my laptop, dont know anything about flashing firmware, can it be done manually? any help would be great thanks!
                                I have connected the box and all the channels are there but I can only view rte, nothing else works, they seem to be scrambled, can anyone help me??
