### New Keys are HERE!!! ###
This topic is closed.
  • Eliminator
    • 30
    #211
    Originally posted by Hammer1973
    Will try codes if keymaster can be opened!!!
    go to page 19, post 184 on this thread
    • daknin
      Just followed the instructions and my 500c is working again. Thanks for the info.
      • ocrim
        • 107
        #213
        hi i need help for eurovox max
        • boocay06
          • 30
          #214
          thanx, got mine workin
          • rapiddave
            #215
            hi all new to all this need HELPPPP with my sv box can any1 give me advise thanks to all
            • bigbob2009
              • 17
              #216
              how many do you have to post to download this s/w?
              • bilko
                The supplier of my box which was pre-coded texted me to tell my the importer had been arrested and that all the codes had been changed (sorry all I know)
                • Jonny2008
                  Hi eveyone. Just want to say thanks for all your help. Still cant get mine working but i'll keep trying.
                  All your hard work is much appreciated
                  • superstar
                    • 15
                    #219
                    thanks for your help guys got my box working - all be temporary :-)
                    • sbance
                      • 48
                      #220
                      my keylist file is completely blank......
                      My keylist file is completely blank.......is this normal?
                      i have entered the keys but none of them work.
                      i have changed the AU to 02
                      I have the Blade Quad image
                      please help!
                      Originally posted by Devilfish
                      Ok folks, don't exactly know what's going on today. Is it a genuine problem with VM? Have they changed the keyroll method? I'm sure we'll find out soon enough.
                      There's a PC application that will give you the keys and they work.
                      The keys are not auto updating for me so manual entry of the keys is required. Either FTP to the box and edit the /var/keys/Keylist.txt (evocamd) or /var/keys/Softcam.Key (mgcamd) file with the new keys or use Tuxbox Commander or another plugin to edit them. The files will most likely have more than one line of keys, the top two are the ones in use, you can delete all other lines. In the KeyMaster application, there is a space between each set of two characters, there should be NO space in the keylist.txt file, it should be a continuous line of 16 characters (0123456789ABCDEF).
                      Using the KeyMaster application, the keys still need to be updated by someone at the other end, it's not an autop update program so if they are not workig, give it time, don't be posting that it doesn't work.
                      If you can manually edit the keys on your box, you'll be ok for the short term.
                      More info when we get it.
                      Njoy!
                      • femmafatal
                        #221
                        kryptview arnet
                        i've read thru the majority of the posts, but cannot see if this works with the kryptview arnet. just loads of posts with folk asking the same question. can anyone assist?
                        • DJDJDJ
                          • 28
                          #222
                          Hi,
                          Just downloading it for Eurovox 5K
                          • shaz2912
                            Sorry complete novice brought 2 arnet A700c boxes for the teenagers pluged in and off we go.Both boxes gone off with message waiting for codes, i know this may sound stupid to some but do i just wait and they will come back on or do i need to do something to the boxes please can someone explain sorry i am really computer illiterate so make it simple thnk you so so much x
                            • kevndee
                              #224
                              how do i manually put new keys in ddigital box
                              • mally
                                Njoy!
                                looks good to me will give it a go, thanks
