### New Keys are HERE!!! ###
This topic is closed.
  • dave2014
    • Oct 2008
    • 68
    #121
    Woo Hoo finally updated my C+W codes manually and all works fine again! Hope there is a fix soon though
    • GATHY
      • 7
      #122
      yep managed to update my key on the ex1000 slim (leeds c+w)
      thanks,all works a treat again
      • Cable Baron
        • 99
        #123
        thanks for the programme, keymaster, it worked fine for me.
        • jpowell2008
          #124
          cant open keymaster for files
          wont allow me to open program. is there any nice person out there that can send me codes as my kids are drivin me insane for tv. thanks
          • AirShowNut
            • 329
            #125
            CORKING advice.Worked a dream (no pun intended ).Thanks Devilfish.
            • thecableguydee
              Awesome, let see if it works!
              • squirreluk
                • 30
                #127
                Keymaster fails to inialise~?
                Is anyone else getting this message when they run keymaster. Ive downloaded it 3 times and get the same responce each time.
                • langmad
                  • 5
                  #128
                  Starview codes
                  I have the same problem. I downloaded the Keymaster RAR file and unpacked it but when I try to open it a warning note appears saying "this application failed to initialise". Can some kind person explain how I can open the file or PM me the latest codes for NTL Leicester.
                  Regards
                  langmad
                  • blagger
                    intro
                    thnaks for help in joining will be more talkative when i get used to things ok
                    • nadzx
                      #130
                      starview 3
                      getting really annoyed of trying to find solutions, hope this works, thanks in advance
                      • AHAC85
                        • 29
                        #131
                        file is downloaded as corrupt
                        Originally posted by Devilfish
                        Ok folks, don't exactly know what's going on today. Is it a genuine problem with VM? Have they changed the keyroll method? I'm sure we'll find out soon enough.
                        There's a PC application that will give you the keys and they work.
                        The keys are not auto updating for me so manual entry of the keys is required. Either FTP to the box and edit the /var/keys/Keylist.txt (evocamd) or /var/keys/Softcam.Key (mgcamd) file with the new keys or use Tuxbox Commander or another plugin to edit them. The files will most likely have more than one line of keys, the top two are the ones in use, you can delete all other lines. In the KeyMaster application, there is a space between each set of two characters, there should be NO space in the keylist.txt file, it should be a continuous line of 16 characters (0123456789ABCDEF).
                        Using the KeyMaster application, the keys still need to be updated by someone at the other end, it's not an autop update program so if they are not workig, give it time, don't be posting that it doesn't work.
                        If you can manually edit the keys on your box, you'll be ok for the short term.
                        More info when we get it.
                        Njoy!
                        • fattonyr
                          • 4
                          #132
                          thnx for the keys
                          thnx for the keys man, life sava
                          • AHAC85
                            • 29
                            #133
                            hi im unable to download the keymaster file can anyone help
                            • fattonyr
                              • 4
                              #134
                              thnx
                              • postie34
                                #135
                                help
                                helppppp !!!!!!
