I would be grateful if any one can help with my problem I have no sound on my SV3
NEW MEMBERS TUT HOW TO INSTALL THE KEYS 28/11/08
This topic is closed.
Well it's so much easier through a router,as you will find it's a lot quicker than using a null modem cable on a serial interface.Sorry mate, i'm not using a router, i have just added the DK1.1 image to my dreambox through an rs232 cable and re-connected my dreambox to my tv and going through your guide that way.
Can this only be done through a router then ?
I do have a router but its not setup.....
Cheers
Can you set the router up,all it needs is plugging in, no real set up required..is the router you have wireless or not ? i use wireless much much easier..Comment
Thanx
Thanx for the info mate, first time i've done it, (i suppose i'm a VIRGIN!!!!) HA HA HA. It worked a treat, and it sounds more difficult than it actually is. thanks once again, keep up the good work.Comment
Yes mate,my router is wireless
Does the Dreambox need to be connected to the router through an ethernet cable or is the dreambox wireless enabled...
What is the best setup to do this....
Sorry to bother you mate but there is some good sport on this weekend.....
This is really simple then we will have you up and running soon, Connect the DM500C into the router and try installing the DK1.1 Addon update again.
You are getting there !!
Just to Clarify, The DM500C is not wireless enabled...once you connect the DM500C to your router you will able to download and update straight from the DM500C via the DK1.1 image.Last edited by Dazzonamission; 28 November, 2008, 13:23.Comment
Ok you really do need the router working in order to simplify things,the DM500C connected via a ethernet cable should be plug and play ...
Turn router off and reboot DM500C,turn router on..what router do you have ?Comment
Scrap that......I have managed to get the router working....This is really simple then we will have you up and running soon, Connect the DM500C into the router and try installing the DK1.1 Addon update again.
but do i now need a 3rd ethernet cable to connect my dreambox to the router.
As i have used my only 2 cables connecting the router, modem and pc together
As you can tell i am a newbieComment
All you need is the DM500C connected to the router, to attempt the plugin addon install.
You can always unplug it after you have the update.
Modem to Router
DM500C to Router,as you don't have another cable to connect the pc to the router,leave it unplugged and plug back in after you get the update..Last edited by Dazzonamission; 28 November, 2008, 13:40.Comment
sorry mate i'm being really thick here, but i don't understand how this would be possible without 3 ethernet cables
ok, how would update the DM 500 if there is no internet going to the pc
BTW my computer an tv are nowhere near each other...........could this be the problemLast edited by Jimbob10; 28 November, 2008, 13:57.Comment
Ok i understand, You will not need the pc to do the update as it's all done from the DM500C,so you can unplug the pc, you will however need to connect your DM500C to your router and obviously the modem too.
You will need also to connect your DM500C to your TV so you can see what you are doing.
Is this making any sense ? or am i confusing you
Makes perfect sense now mate, only my dilemma is, my tv is over the other side of the room from my PC so i have no way of connecting all of them together......;DOH
I can't even move my modem etc as when virgin installed it, my modem wire is just enough length to reach the pc......Comment
