i have just bought a starview 7,i had sv4 in the past i would like to know if anyone else in my area has them and they are working ok..(edinburgh)
rabburnit
Yes SVU 7 working all over U.K. Read info in DOWNLOADS
SVU 7 firmware & instructions 27/Sept/10. When flashing box
use Carling 1.03 firmware as that's latest firmware for SVU 7 -
You would need to post back with some detail of your progress.
Did you flash box with Carling 1.03 firmware.
Did you pick up channels when you scanned
Is box connected to router.
Can you view FTA channs
Did you turn on auto-updates in EMU
Did you select U-stream in net-applicationComment
RAB
Hi THANKS FOR YOUR HELP.....GETTING NOWHERE SO FAC.RESET ...NET.APP...USTREAMED....DLOAD CAR 1.3..REMOVED MEM STICK..SELECTED SYMBOL RATE 6952 AND SCANNED CHS GOT 315...THEN 8989 AND CHECKED AUTO UPDATES ON...EXIT MENU SELECTED SCRAMBLED CH AND WAITED NOTHING BUT SCRAMBLED TITLE ON SCREEN....I AM IN A VIRGIN MEDIA AREA SO IF YOU CAN HELP ME OUT THAT WOULD BE GREAT.....CHEERS...Comment
Look in NETWORK & make sure it is set to U-stream.Hi THANKS FOR YOUR HELP.....GETTING NOWHERE SO FAC.RESET ...NET.APP...USTREAMED....DLOAD CAR 1.3..REMOVED MEM STICK..SELECTED SYMBOL RATE 6952 AND SCANNED CHS GOT 315...THEN 8989 AND CHECKED AUTO UPDATES ON...EXIT MENU SELECTED SCRAMBLED CH AND WAITED NOTHING BUT SCRAMBLED TITLE ON SCREEN....I AM IN A VIRGIN MEDIA AREA SO IF YOU CAN HELP ME OUT THAT WOULD BE GREAT.....CHEERS...
Check IP-setup, should show IP address. If not box is not
connecting to router successfully. Power-off router & box, then
power-on router, then box. You didn't say if you could view FTA channs.
Make sure you use straight LAN cable from router to adaptor
and connect adaptor to rs-232 port at back of box.
Check SYSTEM INFORMATION to see is Carling 1.03 installed
successfullyComment
