rabburnit
  • rabburnit
    • Nov 2010
    • 5
    rabburnit
    i have just bought a starview 7,i had sv4 in the past i would like to know if anyone else in my area has them and they are working ok..(edinburgh)
  • EAMO 2
    • 1201
    Yes SVU 7 working all over U.K. Read info in DOWNLOADS
    SVU 7 firmware & instructions 27/Sept/10. When flashing box
    use Carling 1.03 firmware as that's latest firmware for SVU 7
    • rabburnit
      • Nov 2010
      • 5
      rabbburnit
      thanks for your reply but i have tried following the instructios but no joy and i cant see what i am doing wrong this my first time so if you can think of anything else i would be grateful...cheers
      • EAMO 2
        • 1201
        You would need to post back with some detail of your progress.
        Did you flash box with Carling 1.03 firmware.
        Did you pick up channels when you scanned
        Is box connected to router.
        Can you view FTA channs
        Did you turn on auto-updates in EMU
        Did you select U-stream in net-application
        • rabburnit
          • Nov 2010
          • 5
          RAB
          Hi THANKS FOR YOUR HELP.....GETTING NOWHERE SO FAC.RESET ...NET.APP...USTREAMED....DLOAD CAR 1.3..REMOVED MEM STICK..SELECTED SYMBOL RATE 6952 AND SCANNED CHS GOT 315...THEN 8989 AND CHECKED AUTO UPDATES ON...EXIT MENU SELECTED SCRAMBLED CH AND WAITED NOTHING BUT SCRAMBLED TITLE ON SCREEN....I AM IN A VIRGIN MEDIA AREA SO IF YOU CAN HELP ME OUT THAT WOULD BE GREAT.....CHEERS...
          • EAMO 2
            • 1201
            Look in NETWORK & make sure it is set to U-stream.
            Check IP-setup, should show IP address. If not box is not
            connecting to router successfully. Power-off router & box, then
            power-on router, then box. You didn't say if you could view FTA channs.
            Make sure you use straight LAN cable from router to adaptor
            and connect adaptor to rs-232 port at back of box.
            Check SYSTEM INFORMATION to see is Carling 1.03 installed
            successfully
            • rabburnit
              • Nov 2010
              • 5
              RABBURNIT
              Hi RAB HERE...GOT THE BOX WORKING WHEN HARD WIRED IT TO ROUTER BUT I HOPE I AM NOT BEING CHEEKY BUT IS THERE A WAY YOU CAN MAKE IT WORK WIRELESS USING THE ROUTER....CHEERS....
              • EAMO 2
                • 1201
                You can use HOMEPLUGS or OPEN_MEDIA wifi bridge but the
                LAN-cable you have is best
