Digivox Firmware AU Fixes
  • cactikid
    • 12017
    #256
    box should have updated firmware on it,try doing this
    menu-system info-ok1004-set default key and emu to on or enable keycode and exit out.
    • CSINGH
      • 11
      #257
      Cactikid thanks for the reply
      I tried that but it is not working.
      I need to check if I got right firmware and keys
      Can you please help me with new keys and the firmware for black digivox xl
      Also pl send me links to download new firmware please.
      • scotlandboy
        • 24
        #258
        Originally posted by bugaloo41
        Fixes for the digivox and digivoxxl attached. Obtained elsewhere. Thanks go to those involved.
        Digivox Fix: Digital Kaos - Downloads - Digivox V4300
        Digivox XL Fix: Digital Kaos - Downloads - Digivox_xl_v1341_api
        Digivox XL Fix (Ireland) : Digital Kaos - Downloads - Digivox XL V1250 (Ireland)
        Today is Friday 30th April 2010 and I am having almost all other Channles but no longer I can get SKY MOVIES and ASIAN Channles these channels are Gone for over 24 Hours but all other Channels are coming fine - I have Digivox XL and ex Telewest.... I have deleted and res-can all channels again and switched off and ON my box and up-dated codes and double check codes but nothing working...It seems like they have not changed CODES, because all other channels coming but no Movies and Asian Channles...I have no idia how to Flash my Box or install anything on and neither I have any idia which cable is required to up-date box...Can you help???.... do you think it's something major....???
        • scotlandboy
          • 24
          #259
          • CSINGH
            • 11
            #260
            PLEASE CAN ANYONE PROVIDE LATEST KEYS OR KEYMASTER FOR DIGIVOX XL. IT IS NOT WORKING.
            • cactikid
              • 12017
              #261
              there are no new keys ,it is a new encryption called nagra3,once your area is on it movies and asian channels are first to go,millions of posts on all forums about n3=no fix.start reading and you will see the bigger picture,in irl we went to n3 8 months ago .
              • CSINGH
                • 11
                #262
                cactikid please provide me with telewest keys just want to make sure i got the right one
                • cactikid
                  • 12017
                  #263
                  if you dont upgrade your firmware box will not work.
                  • CSINGH
                    • 11
                    #264
                    Cactikid thanks for your reply
                    Please help me i got laptop at home
                    Which firmware will i use for black digivox xl and pl send me links
                    also which cable shall i use and how to get that cable
                    pl let me know the procedure
                    • cactikid
                      • 12017
                      #265
                      you already posted a link on one of your posts.
                      Digital Kaos - Downloads - DOWNLOADER 10
                      firstly you need the loader,downloader 10,then the latest firmware which is all on site,and depending on your pc a null cable ,or if your pc has no com port,youll need a usb to null adapter. make sure the null cable drivers install properly,check in device manager under lpt/comports,and make sure its set to 1,2,3,or 4 no higher.then open loader set com port to match browse for firmware,and with box powered off hit download,then quickly power box on
                      • cactikid
                        • 12017
                        #266
                        Google Image Result for http://www.hermann-uwe.de/files/images/null_modem_cable.preview.jpg
                        or
                        • CSINGH
                          • 11
                          #267
                          Cactikid your replyes are very helpful
                          couple of things
                          I got laptop at home it got 15 pins female socket how can i use this to download firmware to box.
                          Is there any socket for laptop or i have to use pc only.
                          Last edited by CSINGH; 2 May, 2010, 09:40. Reason: Not allowed to post keys on the forum
                          • cactikid
                            • 12017
                            #268
                            dont post keys on forum its a big no no,remove by editing your post before mods see it
                            they look ok ,as your firmware is not
                            pc with com port is best ,second link is a usb type.
                            • cactikid
                              • 12017
                              #269
                              look at hitecks pictures for guidance as that is a different box.
                              • CSINGH
                                • 11
                                #270
                                [QUOTE=CSINGH;569148]Cactikid where can i that laptop cable
