Channel 808
  • redpieman
    Channel 808
    Just been flicking through the channels and found a warning message from VM about the 6th Dec. Anyone seen this or know what it is referring to?
  • RaRa
    • 4
    I too have found this about 6/12/08 at 10pm. Don't know what it is or whether VM have any access to the box. I am hoping someone on this forum may know something?
    Cheers
    • swanseajac
      • 5
      a friend has seen it,saying the box was counterfit they were viewing on.is the shit about to hit fan,they have tried there best to knock boxes this time
      • RaRa
        • 4
        I don't know... and do hope they've not come up with sommat. I've only had my DV XL box for about 7 weeks and am only just learning about it.
        • bugaloo41
          • 1598
          ignore the message its there to scare you and has been on your box for the last few months. its transmitted on a spare transponder that these boxes pick up.
          • dctyper
            • 2539
            just delete it
            Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
            previous life dm800hd and 500c on cable screw you nag3
            • phillcool
              • 16
              What’s happing on the 6/12/08 then?
              • dctyper
                • 2539
                i havent got it, where are you guys
                • tay72dog
                  • 13
                  Originally posted by phillcool
                  What?s happing on the 6/12/08 then?
                  all ilegal boxes will self distruct if conected!
                  • clit-eastwood
                    • Aug 2008
                    • 339
                    Ha Ha Ha ........................
                    • Neil
                      • 194
                      VM set the channel numbers and channels up on the genuine boxes. If you have a dreambox etc then you do a scan and find all the channels. This scare channel will be found and you will see it. On genuine VM boxes they don't add it to the channel list so you wont see it on a real box.
                      I hope that explains this little scare tactic away.
                      500c, 600c, 7025+cc, 7000s with a 1m steerable dish
                      • dctyper
                        • 2539
                        i have seen the other channels but not this one, never mind i must be aloud to use mine
                        • n1koolkat
                          • Jun 2009
                          • 8
                          Thanks. I was all set to panic. I've only had mine for 24 hours and was flicking through wen i came across it. It doesn't mention anything about the 6th December though.
