Timer function
Finally settled for below player and it does the job (however this is not the best
[ame=http://www.amazon.co.uk/EMTEC-Movie-Cube-S800-multimedia/dp/B001GXZ23U/]EMTEC Movie Cube S800 - Digital multimedia receiver: Amazon.co.uk: Electronics[/ame]
When I recently check KV menu I found that there is a timer. How cool...
but, when I tried to use that for sceduled recordings, it seems not working properly. When I set a timer, player starts correctly at the specified time but it does NOT change the channel I set on there.
Can someone please test this and let me know if it works? Is there any way to correct this (I mean by a firmware update or some kind?)
Thanks for your support
but, when I tried to use that for sceduled recordings, it seems not working properly. When I set a timer, player starts correctly at the specified time but it does NOT change the channel I set on there.Can someone please test this and let me know if it works? Is there any way to correct this (I mean by a firmware update or some kind?)
