Record KV output
  • Vips
    • 29
    #16
    Timer function
    Finally settled for below player and it does the job (however this is not the best
    [ame=http://www.amazon.co.uk/EMTEC-Movie-Cube-S800-multimedia/dp/B001GXZ23U/]EMTEC Movie Cube S800 - Digital multimedia receiver: Amazon.co.uk: Electronics[/ame]
    When I recently check KV menu I found that there is a timer. How cool... but, when I tried to use that for sceduled recordings, it seems not working properly. When I set a timer, player starts correctly at the specified time but it does NOT change the channel I set on there.
    Can someone please test this and let me know if it works? Is there any way to correct this (I mean by a firmware update or some kind?)
    Thanks for your support
    • cactikid
      • 12017
      #17
      maybe you have to be on that channel first to set the timer as i have a combo box and i have to be on that channel to set the timer function.
      • crazier
        • 11
        #18
        recording kv out put
        Yes i do it i have a dvd recorder plus 160 gig hard drive in it i can recored to dvd or hard drive it as a usb in it which i can transfer the contence of the hard drive to my pc this is it
        http://www.argos.co.uk/static/Product/partNumber/5338186.htm?CMPID=GS001&_$ja=tsid:11527%7Ccc:%7Cpr d:5338186%7Ccat:home+entertainment+and+sat+nav+%2F +dvd%2C+blu+ray+and+video+%2F+dvd+recorders+with+h ard+disk+drive+%2F
        It works exellent you can set the recording to various fromats when recording to hard drive the only poblem is the timer function on the kv box is shite.
        • Vips
          • 29
          #19
          You mean you use timer function? But my problem is, KV starts and ends on the specified times correctly, but it does not change the channel I set on the timer. It always starts on the channel I last watched. Currently I have to manually change to the wanted channel and then power off. But the problem is I cannot set 2 timers for diffrent channels
