dell and xp should be ok as they normally have a serial port and are easily used.
so the box has the latest firmware,you factory reset and rescanned without lan connected,i was led to believe that firmware upgraded the iconnect also,i think just keep trying the on/off/on to connect.can you run cable straight to the internet point of origin
yes dw the guides for flashing say to have power off to box at rear,press download and power on box it should flash/update and reboot.
