Using a Splitter
  • unplayable
    • Apr 2011
    • 40
    Using a Splitter
    If I use a splitter to have both my kryptview and VM box at the same time, will these weaken my signal? Meaning I get poorr quality/less channels/more glitching?
    What if the spliter is connected but the VM box is on standby, will this still affect my signal?
  • nobby12
    • 14
    splitters
    made no diff to mine matey, plus when u flick between channels u get the signal strengh. compared with ,without splitter made no differance .nowt
    • klever19
      • 144
      Same here, never had any glitching or loss of picture above the usual i.e without the splitter.
      • bees2000
        • 61
        You can use the Loop connector ( RF OUT ) to connect a coax straight from kryptview to RF IN on virgin box, no splitter needed.
        • unplayable
          • Apr 2011
          • 40
          Really? didn't know this, I'll check on ebay mate. Whats the name of the cable I'm looking for? thanks
          • unplayable
            • Apr 2011
            • 40
            cable
            Its just a coax cable right? male to male?
            • zee24
              • 3342
              Yeah ive been using a splitter for some years not had a problem, but some people do, it depends on what signal your getting in your area, if its a good one a splitter will hardly make a difference, but if it is already a bad signal without you 'may' have some picture quality probs but thats not a guaranteed.
              • unplayable
                • Apr 2011
                • 40
                never had a problem. usually 72 or 77 on KV box
                • parley
                  • 106
                  2 boxes running off a splitter, they were both great before KV went, since it came back 1st box OK but 2nd all glitchy on a lot of channels and missing channels that 1st box has, transferred the data from 1 to 2 but not made a lot of difference.
                  • bees2000
                    • 61
                    Yep, thats all it is (F connector) type ends.
                    • lac
                      • Apr 2011
                      • 213
                      Swap the ports for the boxes on the splitter,or swap all the connects from one box to the other.
                      • gadgetfiend
                        • Aug 2008
                        • 355
                        I wouldnt advise connecting proper virgin box from loop out on KV, for the simple reason it doesnt have reverse path capability so you wont be able to access interactive services from it but more importantly there will be no talkback to VM from subbed box which isnt wise at all.
                        • unplayable
                          • Apr 2011
                          • 40
                          cheers mate will go with splitter
                          • cactikid
                            • 12017
                            signal on the kv needs to be at 80 for best results.
                            • bees2000
                              • 61
                              Sorry mate, but are you saying connecting to a kryptview with no "talkback", means virgin are going to hunt down any subscriber who arn't "talking back" ???
                              or are you saying you shouldn't try to access interactive channels with this type of set up ?
