workman cut cable
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    #16
    yeah you can take f connector off, coax will be central wire with plastic sheath, then braided wire around it
    • BigfatPaulie
      • Dec 2011
      • 203
      #17
      Why aren't you making the cack handed workman repair it?
      Sent using Tapatalk
      • anno 1366
        • Apr 2010
        • 272
        #18
        [QUOTE=Shady;1570076]yeah you can take f connector off, coax will be central wire with plastic sheath, then braided wire around it[/QUO
        E]
        yes its coax
        • cactikid
          • 12017
          #19
          i would also be thinking of using some sort of shrink wrap to seal moisture out before you bury it again and hopefully tested
          • lac
            • Apr 2011
            • 213
            #20
            Seal it with amalgamating tape that will make it good.
            • anno 1366
              • Apr 2010
              • 272
              #21
              Sent using Tapatalk
              they are in the area today,i told him
              to look out for it ,dont think its going
              to be that much of a problem once i
              locate it ? but i dont think i'll let them
              repair it .tbh i think its only coax with
              no protection so could be easily done
              will let you know the outcome
              • anno 1366
                • Apr 2010
                • 272
                #22
                have now found cable under flagstone and going into lawn,but it doesnt look like coax,it has two cables joined together one smaller than the other,presume one tv other internet? this goes to small box then coax out to krypt box,does anyone know if i can join new cable to old and onto small box on wall ,and what cable is called ,by the way workman says he never done it !,when i mentioned virmins call out charges
                • smoggy
                  • Apr 2009
                  • 12771
                  #23
                  thinner one is the telephone line the other is for TV and Broadband
                  • taffydav
                    • Apr 2011
                    • 333
                    #24
                    your cable will be fibre optic m8
                    • Shady
                      Shite Link King
                      • Dec 2010
                      • 6404
                      #25
                      will it? why will it?
                        So Virmin run fiberoptic into the green boxres in the road, that are protected by tramac and concrete - then into your garden when people slice shovel througfh them - yeah sure they do.
                        Flick a match at see, see what toxic fumes come off it (why vermin have the boxres out houses)
                        GOT TO GO
                        Bye.
                        • anno 1366
                          • Apr 2010
                          • 272
                          #27
                          just opened small box on outside wall,the wire is split ,the small one bare wires (phone),unscrewed other ,its coax,.so i presume i can split wire ive dug up ,split it and join new coax.then feed it into house bypassing small box? not in any hurry only back-up box
                          • smoggy
                            • Apr 2009
                            • 12771
                            #28
                            no need to bypass box just join your cable together where damaged
                            use something like this
                            • anno 1366
                              • Apr 2010
                              • 272
                              #29
                              thanks but have not dug up where break is,
                              dont know where that is,
                              have dug it where i know it will have live feed
                              once i put new coax to it,i will still have to use
                              a connector like you have advised thanks
                              • geordle
                                • Jul 2011
                                • 99
                                #30
                                apears your going to an awfull lot of trouble for something that wasnt your fault. if it was working before the workmen dug holes then it doesnt take a detective to work out its down to them to fix it get on there case and make them repair it
