Just back in Belfast need help
  • jonny1983ie
    • Aug 2009
    • 19
    Ok so i have just moved away from my lovely DB to a cable only area and turned my box back on. Every time I try a SW update I get a hangging screen for seams forever I did a manual rs232 update using the image downloaded on this site and I have the following info
    date 24/04/2011 (weird thoght the new flash would update this)
    SV pc3.8.00
    hw v3.0.0
    any help pleaseeeeeeeeeee
  • ASEK
    • Feb 2010
    • 1686
    feed live? netid correct for new addy?
    • jonny1983ie
      • Aug 2009
      • 19
      could you expand of feed live please?
      Yes I am only 2 streets over from where I used to use the box.
      Thanks for the quick reply
      • cactikid
        • 12017
        old firmware as it needs the s/w online update first,connected with lan cable?when updated factory reset and rescan from live feed.
        • jonny1983ie
          • Aug 2009
          • 19
          do you mean i need to download a newer image?
          • cactikid
            • 12017
            yes that is what the lan update is by s/w updates the firmware by download off the net.
            • jonny1983ie
              • Aug 2009
              • 19
              I did a reset and full to scan and still hanging at sw download. How long should it take? I remember it not taking more than 5 minutes
              • cactikid
                • 12017
                factory reset again then power off at rear for 30 secs then on,wait 30secs then try lan update.have you got a cable lan connection?
                • jonny1983ie
                  • Aug 2009
                  • 19
                  Yes a working LAN connection
                  I have done it and notice that the channel scan is taking longer than before so we will see how the SW update goes
                  • jonny1983ie
                    • Aug 2009
                    • 19
                    boom straight away is said download will start after reboot.
                    If I have to point to one problem I would say it was after manualy flashing using null cable I did not power the box off long enough.
                    Thanks very much for your helps!
                    • cactikid
                      • 12017
                      when manually flashing box with null modem cable people are in a hurry,box itself reboots when done then you power off and remove cable.
                      glad your sorted.
                      after boxes are flashed/updated a factory reset/rescan is done and not the other way round.
