ONLINE UPDATE FOR KV HD A850
  • TheCoder
    • Jun 2011
    • 693
    #16
    Originally posted by monkeyballs
    also is there anything new or fixes in the update ?
    It appears to be a very 'lite' update only changing the default server address. You'll probably not notice any operational difference at this time although the release of the update may mean the original server address may become invalid at some point in the future.
    If your having difficulty upgrading, then forget it for the moment until you've worked out how things should be connected for proper operation.
    btw, cant say i've actually had a problem with the superhub functionality in the last 18 months. I usually prefer to use my own router (ddwrt) due to a complex setup but when i've switched back to superhub mode for tests its worked just fine.
    • monkeyballs
      • Nov 2010
      • 119
      #17
      okay thanks very much cactikid
      • monkeyballs
        • Nov 2010
        • 119
        #18
        hi i just tried to set it up in modem mode with the router but i wasnt gettting any interent it was connecting through the dlink router but my internet pages wernt loading up and my box obvs wasnt working either i tried messing about in the ip address setting changing the channels etc but nothing would work have i done something wrong here ?
        • cactikid
          • 12017
          #19
          its the super hub you put into modem mode,the link on post 8 tells you what to do first and when done run a lan cable from the super hub and add it into the router,another lan cable goes to the kv.hub router and kv might need to be powered off for 30 secs then on.
          some have mentioned their box was running better after the update.
          • monkeyballs
            • Nov 2010
            • 119
            #20
            yes i managed to set my router up and put the super hub into modem mode and as i said i was getting connected to my dlink router but my internet pages wernt loading up or anything is there no way i can just get the update by downloading it off here n putting it on my usb stick ? .. or can you help me out with my router i dont get why its connected but not loading internet pages up !
            • alex123
              • 832
              #21
              just take your box to a m8s house ( if you have any )that has bt or adsl you dont need cable connection only internet and update then once done you can back up to a usb stick as coder said no change but new version of server so you do need to update as old server will go off
              alex
              ps you will need to have v7 sw to be able to update v6 had lan update but would not connect to update server
              • monkeyballs
                • Nov 2010
                • 119
                #22
                i dont have a clue with all this its too complicated why cant it just be normal and upload it on here to download .. what do you mean by v7 sw and v6 im clueless about all this
                • monkeyballs
                  • Nov 2010
                  • 119
                  #23
                  my software version is 1.01.07 where you gerrin 7 and 6 from ?
                  • cactikid
                    • 12017
                    #24
                    i was told both were the same he means 1.07 which is on your box,you are 100% sure you are in modem mode even though you said you were.no firmwares for the 850 will be found anywhere.
                    • monkeyballs
                      • Nov 2010
                      • 119
                      #25
                      yer positive mate the super hub goes purple when its in modem mode all my channels are scrambled now aswell will this be because i havent updated yet ?
                      • bavehnaa
                        • 13
                        #26
                        Hi did update and rescan however channels still down
                        • taffydav
                          • Apr 2011
                          • 333
                          #27
                          don't panic m8 they off evrywhere
                          • taffydav
                            • Apr 2011
                            • 333
                            #28
                            downt panic they are off everywhere m8
                            • cactikid
                              • 12017
                              #29
                              bt and vm having problems ,should be back now,if not reboot box,modem and router as in power off all units for 30 secs then on.
                              • monkeyballs
                                • Nov 2010
                                • 119
                                #30
                                finally got upgraded went to my mates (cos i do have some) and updated it thru his bt hub hurray
