I-connector software/ firmware & Loader required
  • cactikid
    • 12017
    #31
    ok by popular demand,not for the weak hearted as this video contains bad language and deffo a no no for flashing a kv box.
    I'm a Stripper so Unzip Your Zipper - YouTube
    • Hadron
      • Nov 2012
      • 2102
      #32
      I uploaded the .exe file to Rapidshare & gave Raj3sh the link. He still has the same problem!
      I'm stumped as to what is causing this weird problem???
      • Raj3sh
        • May 2013
        • 28
        #33
        Just a theory; could it be that the TLM DOWNLOADER in it's current format is not compatible with Windows Xp (pro)?
        Has anyone opened (extracted) this MODULE_UPDATER.rar file in Windows Xp before succesfully; fully functional?
        Is this I-conn loader available from the Bigmaq toolbar, cos I know thats where I got my original KV A750 software & Downloader Tool.
        • cactikid
          • 12017
          #34
          i just tried the links here on the threads and it loads correctly and shows start button,so what pc or browser is he using,for different things one might have to use a different browser,i am on firefox 22 i think and on xp.
          • DW190
            • May 2012
            • 1263
            #35
            I doubt its anything to do with the browser, once the rar file is downloaded its in the docs of his computer and accessable without any browser programme. If anything it could be the operating system but I'm sure I used it back in the day of XP. (couldn't afford Pro so gould have been any other).
            Where abouts in the country does raj reside. may be local to some good hearted gent like myself.
            • Hadron
              • Nov 2012
              • 2102
              #36
              I tried it on my old pc with XP Pro SP3, and also on a laptop with XP Home SP3. Worked fine on both.
              I have had problems in the past downloading some zip files with IE9, but the files were corrupted & wouldn't open at all, so I don't think it's a browser problem.
              On the other hand it wouldn't do any harm to try another browser.
              It's strange that this appears to be a unique problem, yet it has occured on 2 computers that Raj3sh has tried?
              • cactikid
                • 12017
                #37
                are they in administrator mode as exe will be logged as a threat
                • Hadron
                  • Nov 2012
                  • 2102
                  #38
                  I suppose another program could be conflicting somehow.
                  It may be worth booting the pc in Safe Mode & see how it runs then.
                  • cactikid
                    • 12017
                    #39
                    what about java,adobe and all those other things we take for granted as i know all mine are current?try another pc?
                    • TheCoder
                      • Jun 2011
                      • 693
                      #40
                      The main box firmware should automatically load the appropriate firmware to the Iconnector. Attempting to load things to the Iconnector manually could easily lead to mismatch between the Iconnector and the stb although, in most cases, the stb will simply reflash the Iconnector with the proper version.
                      • cactikid
                        • 12017
                        #41
                        the file and loader are only for the iconnect as they are different ,there is a module update on the other forum also.
                        • Hadron
                          • Nov 2012
                          • 2102
                          #42
                          The strange thing is, he has tried it on a laptop as well as a pc with the same results.
                          • Raj3sh
                            • May 2013
                            • 28
                            #43
                            Dear Members,
                            Regarding the Instructions previously given about how to flash firmware onto I-conn:
                            Connect to computer with rs232 Null modem cable.
                            1. Run Loader
                            2. Open and select Software
                            3. Select correct Port
                            4. Hit Start
                            I just thought I'd ask? Do you definitely NOT have an Internet connection connected to the I-conn. whist trying tio flash firmware onto the I-conn......... or do you?
                            Please could you let us know.
                            Thank you
                            • DW190
                              • May 2012
                              • 1263
                              #44
                              Originally posted by Raj3sh
                              Dear Members,
                              1. Run Loader
                              4. Hit Start
                              Thank you
                              1. Run Loader
                              2. Select and open software.
                              3. Select correct port
                              4. Make sure I-connector is powered OFF and is not connected to internet.
                              5. Hit Start
                              6. Power On Iconnector.
                              Wait till Complete.
                              When you connect to the A750 the display should show Module Updating.
                              • DW190
                                • May 2012
                                • 1263
                                #45
                                The main box software will auto update the Iconn with the appropriate firmware as long as the Iconn is functioning correctly. The software and Iconn loader are for recovering Iconns showing only the power light or in other words the firmware has gone corrupt. It loads the original firmware.
