Remote not working..? but works at friends house?
  • 003294
    • 115
    I have KV A780 remote or so i though was not working. I purchased a new one and that did not work either..? I took both old and new remote to friends house and both remotes work. My conclusion box is faulty, but this is surely un-heard of.?
    I have clear sight of box, no obstructions so any help appreciated and no I can't factory re-set REMOTE NOT WORKING?
    Any ideas appreciated
    Have you turned your box on sorry
    • 003294
      • 115
      Yes, box works but I gotta press buttons on box to make it work
        is there a clear plastic covering over the lcd display ???
        • faflefevre
          • 163
          its a fairly common problem caused by the ir remote sensor
            So you know how to fix it then ??
            • mtv1
              The Stig PT
              • 4413
              open the box
              take fronth cover off
              locate the ir sensor
              make shure its visible through the window ( a little push with your finger usually helps )
              if that don't work fiitc
              • faflefevre
                • 163
                dont think a push will work unless the solders dry however a replacement will cure it
                • faflefevre
                  • 163
                  i certainly do maca
                    Originally posted by faflefevre
                    i certainly do maca
                    Tell him then ffs
                    • faflefevre
                      • 163
                      i have ffs.
                      a replacement ir sensor will cure it
                        ffs oh yeah you did
