I DON'T HAVE THE OPTION CALLED "S/W UPGRADE" INSTEAD I GOT "S/W DOWNLOAD" BUT THAT DOESN'T DO ANYTHING
Kryptview Firmware Loading Guide / Tutorial.
hello guys,
1) I connect my STB with computer using USB null cable.
download STB editor
Download the Image file from this website.
when i try to upload the Image file, it says
( Download Is Not Requested ).
what i am doing wrong?
2) try to download something from STB to PC.
Same error message.
3) I shitch the STB off from plug,then When i click on start to upload Image to box, I plug the STB back on.
but still same error message.
any idea?
I bought this box brand new online, the funny thing is it has no option under installation to ( S/W update ). which I had in my old box which burn due to electric shock.Comment
Hi, guys..
I think i've read and re-read this thread 2-3 times but i'm stuck on what seems to be nearly the final stage.
I've flashed, uploaded the A750 F/W and then connected it to the TV, factory reset, connected the i-conn and then scanned for channels. BUT, my i-conn is only displaying a single green light which is the Power one.
My i-conn's lights were all flickering earlier on the old firmware, which nearly eliminates hardware problems.
Anyone been in a similar situation or has a walk-around?
Thank youComment
DW190
It dont i tried to download the loaders and firmware but it says windows cnt open the file ???? plzzz help really wnt this to work igot krypti a750Comment
You came on DK, downloaded any necessary files.
When you had a problem you asked for help.
When you resolved problem you posted back;
I'M ALRIGHT JACK-------F**K YOU
That's not good enough. If I was A moderator you would be banned until you posted an apology to DK membership for
your selfish behaviour. If you had not resolved your issue
my money says you would be on here pleading for helpComment
my A780 stopped working after aprox 6 months says scramble signal as the softwware run out cause it wus allready on when i got it if so how do i get it bk on again iv tried resetting it appreciate any help cheersComment
Hi Guy's I have the same problem as mentioned many times here, STB Editor, The downloading is not requested??
I'm using a null modem cable and I'm in Com 1 but still keep getting the same msg?
I have followed the instructions posted many times but to no avail.
Very fustrating :'(Comment
