how to set up kryptview a780 box
  • pspmixer
    • Jun 2009
    • 750
    I installed a kryptview box in friends other month, now he has decided to move box up stairs, can someone tell me how to do a factory reset and re scan so can guide him over the phone to do this thanks
    Setting up the Kryptview KV780 Cable Receiver - YouTube
    • pspmixer
      • Jun 2009
      • 750
      bit hard to follow, what do you press on remote plus select on screen
      • ASEK
        • Feb 2010
        • 1686
        shouldn't need to do anything bar plug it in.
        • pspmixer
          • Jun 2009
          • 750
          im trying to help someone over the phone so ideally need how to in written form thanks
          • ASEK
            • Feb 2010
            • 1686
            if u put it in for him and scanned it, all he needs to do is, run cable upstairs with an internet connection, no need for anything, its moreorless plug n play u have already set it up.
            • pspmixer
              • Jun 2009
              • 750
              so what is the steps to take then in order
              • cactikid
                • 12017
                i would say only thing might be needed is a factory reset/rescan from direct feed,choose correct provider and net id,did you leave a note of what provider and net id was when setup over there?? no bad show
                password when doing factory reset 0000.
                • pspmixer
                  • Jun 2009
                  • 750
                  yeah I told him to select telewest can you tell me step by step please
                  • PremierD
                    TAMINATOR
                    • Jun 2009
                    • 13243
                    • ASEK
                      • Feb 2010
                      • 1686
                      ur kidding? lift box go up 14 or more steps screw cable in and that's it.
                        Its not the 1st of april is it......................
                        • pspmixer
                          • Jun 2009
                          • 750
                          he said it had no signal he done a scan and still said no signal so what to tell how to do factory reset then scan
                          no its not its latest one from here
                          • jw2000uk
                            • 37
                            Has he even got a telewest coax upstairs :-/ ?
                            Or has he just plugged it in..
                            Simplest of jobs this should have been.
                            • pspmixer
                              • Jun 2009
                              • 750
                              yes a virgin one he has got, should of yes
