new online update for 850 hd
  • joe516
    • 1000
    There is a new update available for the HD box
    SV 1.02.07 -- May 26 2014
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
  • mels101
    • Jan 2014
    • 25
    Is there any noticeable changes in this update?
    • joe516
      • 1000
      no m8...................
      • monkeyballs
        • Nov 2010
        • 119
        is there any other way i can get the software off the internet download onto a usb stick as it dosent update through the virgin super hub help please !
        • mels101
          • Jan 2014
          • 25
          If there isn't any changes in the firmware, it might not be worth the hassle upgrading / rescanning channels. Are firmware upgrades not meant to include fixes, improve stability or new epg etc? Its a bit like a PC motherboard when a new bios upgrade gets released, some says if its not broke, don't upgrade it....
          • cactikid
            • 12017
            someone does not listen heard of downloads??
            kryptview a850 hd 26052014 file - Downloads - Digital Kaos
            dont upgrade and be left behind like others when box went off.
            • Digicom
              • 190
              Already posted in Downloads
              • fo08aam
                • 43
                Hi All, Sorry if there is an obvious answer to this question. I have V rgin media superhub therefore cannot download via internet. What's the procedure from doing it via downloading the disc image from the download section.
                please let me know. Thanks in advan
                • digicon
                  • 8261
                  you just click on the Blue box that has "+ Download" written inside of it.
                  • cactikid
                    • 12017
                    oooooops saw this and forgot to add how to
                    if file is in rar format it needs extracting first by a program called winrar also in downloads under pc,copy the file to usb as per instructions underneath.[/COLOR]
                    and no it does not come with the box.
                    flashing the box
                    Please follow the instructions below
                    (1) Format a usb pen drive to FAT32 on your PC first
                    (2) Then get the file you have downloaded and copy it across to the usb then
                    (3) Turn the box off at the back and put the USB into the front of the box
                    (4) Then turn the power back on to the box when the box powers up go to the menu and select Software upgrade press ok
                    (5) Then allow the box to reboot, after that you will see the cable scan option just scan as with the older box
                    Ps if you see on screen usb initializing all the time your USB pen has not been formatted to Fat 32
                    Phoenix HD A850 Cable box - YouTube
                    GUYS WHEN SCANNING FOR CHANNELS YOU MIGHT NEED TO SCAN ON ALL OF THE PROVIDERS MAKING SURE YOU FACTORY DEFAULT THE BOX EACH TIME, SO IF NO CHANNELS ON SCAN ON N*l SCAN ON EXCW, THEN TW, AREAS HAVE CHANGED OVER THE LAST FEW WEEKS AND AREAS HAVE BEEN CHANGED
                    • roblfcx5
                      • Nov 2012
                      • 239
                      The Superhub is OK to do a online update
                      Sent from my GT-I9505 using Tapatalk
                      • phil14
                        • Aug 2012
                        • 10
                        it does update from super hub done mine with no problem
