Hi all I have a slight problem I installed a a780 yesterday and got it up and running but the thing is when I have connected it it has knocked my catch up on demand off on my tivo box is there any way around this please it comes back on when I disconnect my a780 box many thanks
My box
Tags: None
so you have the feed coming into a double splitter, then each of the 2 cables ( 1 to KV and the other to Tivo ).
also do you have an 2 ethernet cables 1 for each box, direct to your router ?
it sounds like your KV is taking over the main signal, therefore knocking off the Catch up TV service to you KV.
I aint clued up on the tivo, but does it 2 connections on the tuner, i am thinking maybe on the "out" connection on the Tivo to the "In" connection on the KV.
Do you have a cable feed in a different room ?
either way someone on here will get you sorted.Last edited by aftermath; 7 June, 2014, 17:08.
