Hi, greetings guys. Please kindly assist. Am having difficulty with the installation of the box with my Tv. I use indoor arial in my room where am used to getting few channels but as soon as i connected the box with the tv through the scarlet plug. I switched on the box and my program went off, showing no signal/bad signal. Pls what can i do to rectify this. Thanks all.
Installation of kriptview
welcome to dk olly am i reading this right you connect your kryptview up to aerial? this is a cable receiver it wont work on aerial. if it is connected to the cable feed tho when you switch box on it would have selected another av channel, turn it off and the tv should return to its previous status. However if it is showing bad or no signal it may just need flashing with correct firmwareLast edited by wilf; 28 October, 2009, 01:31. -
kryptview
hello all
having all kinds of problems installing kryptview A750
followed tutorials about flashing but keep getting "downloading not requested" on the STB editor.
i am sure i have the correct Null cable and the USB converter is all installed with correct driver.
i switch the box off at back, hit start,then in a few seconds i get the evil message
any help?Comment
DW190
Once you have hit start you have to quickly switch the box back Onhello all
any help?Comment
