Kryptview A750 + IConnector latest firmware 03/01/2011
Digital Kaos - Downloads - Kryptview A750 03/01/11
Please be advised that if you upgrade your A750 with the 03/01/2011 firmware, make sure your IConnect is powered OFF when doing the new channel scan.
Only reconnect it and power it back up again once you have a TV signal displayed on the TV (Usually channel 0000).
Once you power up the IConnect, it should take over the A750 and download a major update from the internet. This is normal and should be allowed to proceed (display shows on both the TV and the A750). Once the A750 display shows the word SUCC it is complete and you may now use your IConnect in the manner in which it was designed.
If you get the above wrong, the IConnect will sit there and only display 2 green LED's (power and connection). If this is the case, re-read the above and you have to start from the beginning (re-flash).
