a750
  • antsumner
    • 438
    a750
    hi can anyone tell me if this box works on nagra3
    and if so is it the same setup as the sv6 (lan port)thanks ant
  • wilf
    • 1618
    it works with a i-connector an connects through your router but you may be best to go with the a780 with built in lan and its cheaper than the 750 + i-connector
    • badapple
      • 2041
      Kryptview A750 - Bubble Supplies LTD
      NO m8, this will not work on the nag3 encryption on its own.
      What you will need with this box is a i-connector, then connected to a server it will enable one way C/S.
      But there is another box(cheaper) which has the in-built i-connector and will work like the SV6.
      The A750 box on its own will be preety much useless soon.
      SLOWLY, OUR FREEDOM IS BEING ERASED.
      SOON, WE WILL JUST BE A NUMBER.
      IF WE DON'T FOLLOW, WE WILL BE ERASED.
      • antsumner
        • 438
        ok thanks guys
        • bugaloo41
          • 1598
          Get the a780 mate with built in lan works better than the a750+ iconnector imho.
          Stick to kryptview over starview support is much better.
