it works with a i-connector an connects through your router but you may be best to go with the a780 with built in lan and its cheaper than the 750 + i-connector
hi can anyone tell me if this box works on nagra3 Kryptview A750 - Bubble Supplies LTD
and if so is it the same setup as the sv6 (lan port)thanks ant
NO m8, this will not work on the nag3 encryption on its own.
What you will need with this box is a i-connector, then connected to a server it will enable one way C/S.
But there is another box(cheaper) which has the in-built i-connector and will work like the SV6.
The A750 box on its own will be preety much useless soon.
SLOWLY, OUR FREEDOM IS BEING ERASED.
SOON, WE WILL JUST BE A NUMBER.
IF WE DON'T FOLLOW, WE WILL BE ERASED.
