Kryptview A780 No Channels found
  • jarramix
    • Aug 2009
    • 7
    I have updated the firmware on box rebooted not finding any channels just to clarify that the only cable coming out of box is the ethernet to router
  • jumpinjo
    • 869
    are you scanning your providor and id
    • smoggy
      • Apr 2009
      • 12810
      you need to plug in your cable feed
      • alienxists
        • Aug 2010
        KryptView a780
        where to dowload and how to upload the software in the a780?
        • DW190
          Let me google that for you
          • jarramix
            • Aug 2009
            • 7
            plugged in cable got bout 20 channels for 10 minutes then sreen says scrambled or no video
            • cactikid
              • 12017
              factory reset and auto scan with lan removed,plug in after box has rebooted,maybe need to reboot both units again.
              is it just a bb you have or a min package.
              forgot to mention dont use splitters
              • daza1604
                • Aug 2010
                • 15
                hi there, i have a similar problem.
                Recieved my box the other day and flashed with the latest firmware.
                I scanned for channels yesterday.. selected "4 Telewest" and Network on the search.
                It picked up all the channels sly movies / sports ect but only the FTA channels are working. Scrambled channel is displayed on the subscription channels.
                I have read that you should not use a splitter... this is where i have a problem.. im using VM BB so the splitter is required so my box can have both a cable feed and a connection to the router.
                is there another way around this? Am i gonna have to change my BB reciever? if so will i still then recieve a cable signal to pick up the channels?
                Any help would be greatly appreciated
                Daz
                • DW190
                  Daz
                  You do not mention connecting the ethernet cable to the box and your router.
                  If you have connected the ethernet cable reeboot both the router and the box.
                  • daza1604
                    • Aug 2010
                    • 15
                    Yes sorry, i have connected the ethernet cable.
                    Shall try what you say this afternoon and see how it goes.
                    Fingers Crossed
                    • jumpinjo
                      • 869
                      most peeps use downloads section HERE for files your after
                      • cactikid
                        • 12017
                        wonder if its only bb you have or a min subscription?
                        • jarramix
                          • Aug 2009
                          • 7
                          have min subscription 1 cable in then splits to box and router am i donald sorry to be a d*ck
                          • riprip25
                            • Mar 2010
                            • 8
                            select your net-id
                            then select the nearest id to your place.
                            • cactikid
                              • 12017
                              min package has a higher signal than bb which is reduced,make sure it was the 780 file you downloaded and follow hitecks sticky of how to setup and scan on a 750 same box without a lan port.is your area fully n3 as if its not streamed it wont work as there is no n1 firmware.
